Results 1 to 7 of 7
Thread: Site coordinate input in Revit?
    2005-10
    2
    Default Site coordinate input in Revit?
    I have a problem with inputting my site coordinates. I used to be an AutoCAD user and I used absolute coordinate to input x- and ycoordinates to draw site lines. How can I do the same in Revit Building? My site coordinates are shown in the picture.
    -kimmoi
    All AUGI, all the time christo4robin's Avatar
    2003-05
    Boulder, Colorado
    681
    Default Re: Site coordinate input in Revit?
    I haven't used them myself, but you may want to check on spot coordinates in help. (Drafting bar in the design bar, then spot dimension, then spot coordinate in the options bar.)
    Christopher Herr
    Studio H:T
    Republic of Boulder
    2005-10
    2
    Quote Originally Posted by 4christo4
    Sorry my bad english, but that spot dimensioning is familiar to me. My problem is, how to draw my site using correct coordinates (which are given me by city).
    -kimmoi
    2007-12
    You need to draw your line segments fist in true north. Then use spot coordinate dimension on the end points. Then relocate your project. Then rotate it to project north.
    2015-09
    20
    Not sure if this will solve your problem, but under the Site bar there is a property line tool that allows you to input the meets and bounds as given by a survey. That should get you the property line absolute. Then you can move the property line as needed.
    2004-06
    Memphis TN area
    7,047
    Quote Originally Posted by bbeck.204046 View Post
    It sounds like the OP is outside the USA, and his city government shows site surveys with x,y coordinates, not distances and bearings like on American surveys.
    Unfortunately with spot coordinates, you cannot directly edit the spot coordinate numbers. They merely report the location of the referenced point.
    I'm not sure how you would draw property lines using x,y coordinates.
    AERC, PLLC
    Hernando, Mississippi
    Active Member mrice.47661's Avatar
    2003-02
    Somerville, MA
    52
    Maybe this is a bit too simplistic, but ....
    If you have an AutoCAD file from the city, why not just import that into Revit and use the pick lines tool to create your Revit property lines? Or, if you only have that image to work from ... input the coordinates manually yourself first into AutoCAD (since you indicated you were familiar with that process), and then do the same import into Revit method.
    Or am I missing something here?
  1. Replies: 0
    Last Post: 2014-11-11, 10:39 PM
  2. 2013: Common Coordinate System - Large Site Model
    By Limbatus in forum Revit Architecture - General
    Last Post: 2013-08-01, 08:53 PM
  3. 2013: 3D Cartesian Coordinate System: Batch input with Work Point Labels
    By rusa67 in forum Inventor - General
    Last Post: 2013-02-04, 04:44 PM
  4. Coordinate input to displace instead of move
    By pgastelum77763 in forum AutoCAD General
    Last Post: 2007-03-15, 01:14 PM
  5. Site Coordinate System
    By eckdahlrd in forum AutoCAD Civil 3D - General
    Last Post: 2006-07-28, 02:24 PM
