In Civil3D 2007, if you create an alignment with Curve-Spiral-Curve segments in it, then export this alignment to XML file, the theta,totalY,totalX,tanLong,tanShort attributes and PI element of the Spiral were not correct.
So,if you re-Import the XML, the alignment was different from the original one. Is it a bug?
