irneb
The attached shows the reason I'm talking about. There's 4 layers: 0, Layer1, -2 & -3. A line on each, with a duplicate placed inside a block - this block is inserted on Layer3. Drawing Freeze has everything turned ON, with only Layer3 Frozen, while Drawing OFF has everything Thawed with only Layer3 OFF. Now you can see that the lines inside the block behave VERY DIFFERENT in the 2 scenarios. So depending on what you wanted you may want to use Freeze instead of OFF - irrespective of whether the change should be permanent or not.
