Coolmo
That's what I'd do too but I would just freeze the layer I didn't want to see. Same outcome but I'd be sticking to my very simple rule of Freezing things I don't want to see and keeping ALL layers turned ON. What would be the advantage of turning the layers OFF inside the block instead of just freezing them? I personally don't work with attributes so is it an attribute thing? The only difference that I see in this block situation is if you have a block with 3 entitys on 3 different layers INSIDE the block and the block is inserted onto a 4th layer, when the 4th layer is turned OFF the 3 layers on the INSIDE of the block still show as opposed to if you froze the 4th layer, which would simply not show the 4th layer and also not show everything in the block. I'm really not trying to argue here. I just want to see if I'm missing something that could make me faster in my work.
