Results 1 to 10 of 12
Thread: Setting Plot Style Table in Lisp
    2004-12
    California
    283
    Default Setting Plot Style Table in Lisp
    Afternoon -
    I need to build into my lisp a way to set the appropriate plot style table and make it active.
    I've searched through the forums here and no one really gave an answer, so please do not post links to other posts!
    I've tried the following list with nothing working.....
    (vla-RefreshPlotDeviceInfo objLayout)
    (vla-Put-StyleSheet objLayout "MyStyle.stb")
    ThisDrawing.ActiveLayout.StyleSheet = "MyStyle.stb"
    (vl-load-com)
    (vla-put-PrinterStyleSheetPath (vla-get-Files (vla-get-Preferences (vlax-get-acad-object))) "MyStyle.stb")
    I've attached a pic of the tool itself from the options dialog box but I need a way of doing this from the command line for the lisp routine.
    Any suggestions?
    9,720
    Default Re: Setting Plot Style Table in Lisp
    So are you trying to set "default" STB file (for use with R14 and previous drawings - as your photo shows), or are you trying to set the current STB file for a particular layout?
    IF the former...
     (setq o (vla-get-Output (vla-get-Preferences (vlax-get-acad-object))))
     (vla-put-PlotPolicy o 0)
     (vla-put-DefaultPlotStyleTable o "monochrome.stb")
    IF the latter.....
    See this post for an example of setting the "stylesheet" for multiple layouts in multiple drawings.
    If you just want to operate on the current layout, then here is a lisp example:
      (vla-put-StyleSheet
        (vla-get-ActiveLayout
      	(vla-get-ActiveDocument (vlax-get-acad-object))
        "monochrome.stb"
    2004-12
    California
    283
    I am getting the following error on both routines.....
    "Automation Error. Invalid input"
    What's that?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    8,449
    Quote Originally Posted by fletch97
    What's that?
    Have you run the following function?
    (vl-load-com)
    2004-12
    California
    283
    Nope but I just added it in and I got the same error for the second routine and basically the same error for the first routine except it says "invalid argument" instead of "input".
    Any Ideas?
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    Any Ideas?
    If you did a staight copy and paste of RK's code, does monochrome.stb exist?
    Or if you changed it, can Autocad find the one you are trying to set?
    Just a guess, though.
    HTH
    Tim Creary
    S&D
    DILLIGAF
  1. Change All Layers' Plot Style Setting
    By parker.depriest356295 in forum AutoLISP
    Last Post: 2013-02-05, 07:05 PM
  2. setting the plot style
    By rstiles in forum AutoLISP
    Last Post: 2012-02-10, 07:54 PM
  3. Unable to edit plot style table though plot dialog box
    By mike.smith696451 in forum Land Desktop - General
    Last Post: 2006-12-20, 03:11 PM
  4. Replies: 1
    Last Post: 2006-10-13, 04:58 PM
  5. Plot style Table
    By rputhenv in forum AutoCAD Plotting
    Last Post: 2005-03-05, 08:30 AM
