Results 1 to 9 of 9
Thread: Where is the tools pulldown menu
    2004-10
    Orange County
    211
    Question Where is the tools pulldown menu
    I need the tools pulldown menu for borrowing a license
    Yes I know I can do help about but most users are already used to the tools pulldown menu from acad 2006
    AUGI Addict Mr Cory's Avatar
    2007-01
    Under a Rock over there
    1,006
    Default Re: Where is the tools pulldown menu
    Is it not loaded with the rest of pulldowns? Have you changed your .cui file at all?
    2002-09
    Madison, WI
    5,688
    The tools menu is not generally loaded with ADT. You may be able to find it on the windows/pull down pull down. What tool are you looking for?
    2007-01
    1,006
    True. Was assuming Dave was using CAD, You could customize the format pulldown and place the command (license borrowing) in that pulldown instead of the "tools" one
    2006-12
    Big "D"
    3,711
    In ADT 2007 it is:
    Help
    About
    Click on Product Information in the upper right corner
    Borrow license is at the bottom, middle.
    Hope that helps
    2006-12
    Big "D"
    3,711
    oops, I just read your request again and you already know "help, about". I need to quit skimming over what people write and actually read it!
    2004-10
    Orange County
    211
    Question Re: Where is the tools pulldown menu
    Again the issue is that there are hundreds of users in my company
    I cannot issue a statement saying modify your cui even if I could figure it out
    I just want the tools pulldown menu loaded in the OTB ADT.
    2002-09
    Madison, WI
    5,688
    Do you want to install ADT as Acad or as ADT? There's an option to run ADT as Acad. If you can figure out the CUI, you can export that to a server, and simply have your users load it.
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    Quote Originally Posted by Dave Lewis
    The AutoCAD menu set (which includes the Tools menu pulldown) is seperate from the ADT menu set. To clarify what David posted, you can choose in the installation of ADT to run it as vanilla AutoCAD or as ADT. If you run it as AutoCAD, you have no access to any of the ADT functions and vice versa. If you want BOTH sets of menus, that is not possible ootb. You will have to get into the nitty gritty of the CUI if you want to see the Tools menu, whether you want to get involved with the CUI or not. The users won't need to do anything if you do things right. If you do not want to get into the CUI, then you will have to instruct your users to adapt to their new environment. But that is really skirting the issue and you will be involved with messing with the CUI eventually.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
  1. convert pulldown menu to ribbon
    By andy.millard in forum AutoCAD CUI Menus
    Last Post: 2009-10-23, 05:11 PM
  2. Custom pulldown menu items
    By revituser195 in forum Revit Architecture - General
    Last Post: 2009-04-02, 06:02 PM
  3. AutoCAD 2007 can not locate Express Tools pulldown menu
    By amasella in forum AutoCAD General
    Last Post: 2007-01-19, 07:49 AM
  4. Rearrange Menu Pulldown Order
    By lpseifert in forum AutoCAD CUI Menus
    Last Post: 2006-11-10, 06:46 PM
  5. Placing Enterprise .CUI pulldown Menu
    By cadd4la in forum AutoCAD CUI Menus
    Last Post: 2005-06-16, 01:44 PM
