Thread: calculator
    2006-08
    36
    Default calculator
    Include calculator like in Auto CAD 2007 with RPN option.
    2003-04
    Chino, CA
    4,756
    Default Re: calculator
    Every time you can do dimensional entry in Revit, its a calculator. Try this: select an object, and then pick Move. Click a start point, and then move the cursor in the direction you want to move. Type an = sign (which will appear on screen in the data entry box) and then a mathematical expression...
    =4'/2 will move the object 2 feet. Obviously a very simple example, but you can do any basic calculation plus many scientific calcs as well.
    2006-09
    442
    Thats cool. Out of curiosity is this function listed anywhere in the Help menu, because I didn't see it there.
    2007-02
    Hendo, Nevada
    99
    Wink Re: calculator
    revit...secrets...
  1. Stair Calculator?
    By barrie.sharp in forum Revit Architecture - General
    Last Post: 2011-05-27, 02:01 PM
  2. Calculator?
    By david_peterson in forum Revit Structure - General
    Last Post: 2009-07-22, 03:11 PM
  3. Ellipse Calculator.
    By Mike_R in forum AutoLISP
    Last Post: 2007-06-28, 06:09 PM
