I need a Spot Elevation symbol, with a fully functioning leader, but that I can point at anything and fill in the text. We have not only complex flat roofs that can't be modeled but must be annotated, but also scuppers and drains and top of curb and top of parapet and other such that need to be annotated. Even "top of" stuff wants to point to the edge of the parapet or curb, and we need it to point at the top surface of the wall, not the face.
So, has anyone found a good way to do this in a single family? At this point I am about to do an elevation symbol and text, then do a Keynote Type with no text. Lame!
Also, with the regular Spot Elevation, is it possible to control which side the text is on? Currently the text is on the same side as the leader, which sometimes requires a large dogleg for some text. We would much prefer the dogleg just be what it needs to be, and the text go off the other side. And then lastly, the current spot elevation doesn't have anyplace to note what is being located, "T.O.Parapet", that kind of thing. But when you open the Spot Elevation - Target Filled family to edit, all it really is is the graphic, there is no text there to move, or add an instance parameter for some extra text.
Thanks for any recommendations.
Gordon
