Thread: Dynamic Block door, update text automatically as door is changed
    100 Club Matt Mercer's Avatar
    2004-05
    Liberty Lake, WA
    147
    Default Dynamic Block door, update text automatically as door is changed
    I'm new with the Dynamic Blocks. Thanks for your sharing, I have learned some so far, but I have a problem that I can not seem to figure out. I have a door block and I want the door size to automatic change when I change the door. I assume I can change it by the "lookup". I can not seem to connect my text (which is an attribute) to my lookup - I guess I might be way too confused. Here is what I got so far.
    Thanks Matt
    Retired Forum Staff Rico's Avatar
    2005-06
    In the hospital cuz of my fever for more cowbell
    1,828
    Default Re: Dynamic Block door, update text automatically as door is changed
    Quote Originally Posted by Matt Mercer
    Thanks Matt
    all you need to do is add a field that connects your rotated dimension to your attribute.
    On a side note, my humble opinion is that nothing should really be placed on the Defpoints layer as it is an AutoCAD created layer and is meant to be used by the system only as a point of reference for dimensions. My suggestion is to create a no-plot layer and place the dimension on that. Good idea on keeping the dimension to a no plot, though. If you carry that attribute through to all the vis states, it should be what you're looking for.
    Maybe change the orientation of the attribute or something ....
    [SIGPIC][/SIGPIC]
    Return of the Cowbell
  1. 2016: dynamic block to write automatically door width value and door type accordingly.
    By architurk in forum Dynamic Blocks - Technical
    Last Post: 2015-08-24, 09:14 PM
  2. Dynamic Door Block Stretch
    By sovby254640 in forum Dynamic Blocks - Technical
    Last Post: 2014-11-18, 05:05 PM
  3. Dynamic Door Block
    By harilalmn in forum AutoCAD General
    Last Post: 2010-08-04, 04:21 PM
  4. Replies: 1
    Last Post: 2008-09-17, 04:23 PM
  5. Replies: 19
    Last Post: 2007-03-27, 08:47 PM
