Results 1 to 6 of 6
Thread: Trimming multiple lines in AutoCAD LT 2005
    2003-10
    United Kingdom
    50
    Default Trimming multiple lines in AutoCAD LT 2005
    Hello all,
    I have recently moved back from Autocad 2007 to Autocad 2005LT (changed job), and when trimming multiple lines, rather than just use the mouse to select the rest of the lines i want to trim, I have to select every single line?
    My question is, is there a way to trim multiply lines quickly rather than selecting every one of them one by one, or the only way is to use the fence function to trim them? Maybe its just a setting(s) I couldnt find from the option menu?
    Many thanks
    Vince
    All AUGI, all the time bbapties's Avatar
    2003-12
    Palm Harbor, FL
    537
    Default Re: Trimming multiple lines in AutoCAD LT 2005
    as far as I know fence is your only option in 05'
    If that is an option in 07' that is a great addition to the trim and extend command.
    13,656
    Quote Originally Posted by vince.59412
    [ SNIP ]
    Hi Vince
    Please note I have *moved* this thread from the AutoCAD General forum to this one...
    Thanks, Mike
    Forum Manager
    Member egoss's Avatar
    2005-12
    17
    Back in Auto Cad 14 there was a Bonus command for multi-line trim. I have not seen it in any other versions. I used it all the time. Now I have 2005 and I just use the fence command.
    2007-11
    _extrim works in most versions, not sure about LT
    0,0,0 The Origin
    8,570
    Quote Originally Posted by anne-marie.x.tait View Post
    Not in LT including 2008LT.
    John B
  1. Trimming Lines.
    By richard.stierman177618 in forum AutoCAD General
    Last Post: 2008-10-23, 05:06 AM
  2. Replies: 5
    Last Post: 2007-04-13, 12:26 PM
  3. AutoCAD 2005 - Copy no longer multiple by default?
    By VirtualBuilding in forum AutoCAD General
    Last Post: 2006-02-07, 09:20 PM
  4. Disable multiple Copy in AutoCAD 2005
    By robert.1.hall72202 in forum AutoCAD General
    Last Post: 2005-04-12, 08:11 PM
  5. Create and share multiple Tool Palettes in AutoCAD 2005
    By caduzer in forum AutoCAD Customization
    Last Post: 2004-12-08, 07:46 PM
