Thread: GLASS RAILING
    2003-10
    Santa Barbara
    397
    Question GLASS RAILING
    I am trying to create cantelevered a glass railing but cant see a way to have zero balusters
    am I missing something?
    2003-05
    5,153
    Default Re: GLASS RAILING
    Just make a wall 6mm thick ( or whatever) and assign a glass material.
    2003-04
    Chino, CA
    4,756
    I would make custom ballusters that are glass panels. Then you can space the panels however you'd like. Although they are called 'balluster' families, they are really quite capable of being almost any element in a custon stair. There was some custom stair examples here in the past, and Phil Read from Revit is the Stairmaster!
  1. Glass railing Question - Corners
    By sbrown in forum Revit Architecture - General
    Last Post: 2020-07-06, 10:15 PM
  2. Glass Panel Railing
    By dboggs in forum ACA/AMEP Styles Library
    Last Post: 2017-12-06, 09:19 PM
  3. 2012: Glass Balustrade panel railing
    By damon.sidel in forum Revit Architecture - Families
    Last Post: 2012-08-08, 11:26 PM
  4. Glass in Railing
    By austec in forum ACA General
    Last Post: 2007-12-19, 10:05 PM
