Results 1 to 10 of 14
Thread: Extracting Object Data into an Attributed Block
    Question Extracting Object Data into an Attributed Block
    Hello Folks,
    I was wondering how I can use VBA to extract object data information from an object and put that information into an attributed block. I think I have to go along the ODtable.getODRecords or ODFieldValue way but i'm not to sure how to go about it. If you could lead me in the right direction that would be wonderful.
    Thank you
    2000-01
    Seattle WA USA
    5,859
    Default Re: Extracting Object Data into an Attributed Block
    What version of AutoCAD are you using? If you have AutoCAD 2005, take a look at Fields.
    Arizona
    2,478
    If this user were to use fields then the question would
    need to be how does he extract object data to fill in those fields?
    6,419
    Only if he has 2005. I think Robert's just waiting for his response so that he doesn't provide an answer that's not needed.
    LinkedIn
    Administrator richard.binning's Avatar
    In the foothills of the appalachians
    2,261
    Quote Originally Posted by brennan.cunningham
    Hello Folks,
    Thank you
    ODtable.getODRecords? Sounds suspiciously like the OpenDrawing libraries to me. Is that right?
    Arizona
    2,478
    The user is attempting to extract AutoDesk MAP
    Object Data Records into block attributes.
    Yes I am using Autocad Map 3D 2005. I was given this code as an example but it doesn't seem to work.
    __________________________________________________________
      Dim ODrcs As ODRecords
      Dim returnObj As AcadObject
      Dim i As Integer
      Dim strMsg As String
      Dim boolVal
      Set amap = ThisDrawing.Application.GetInterfaceObject("AutoCADMap.Application")
      Set ODrcs = amap.Projects.item(ThisDrawing).ODTables.item("MY_OD_TABLE_NAME").GetODRecords
      'Prompt user to select an object
      ThisDrawing.Utility.GetEntity returnObj, basePnt, "Select an object"
      boolVal = ODrcs.Init(returnObj, True, False)
      strMsg = ODrcs.Record.tableName & vbNewLine
      strMsg = strMsg & ODrcs.Record.objectID & vbNewLine
      For i = 0 To ODrcs.Record.count - 1
        strMsg = strMsg & ODrcs.Record.item(i).Value & vbNewLine
      Next i
      MsgBox strMsg
    I always get a run time error on this line:
    any suggestions?
    2000-01
    Seattle WA USA
    5,859
    Do you have more than one version installed?
    Does this make a difference?
    Set amap = ThisDrawing.Application.GetInterfaceObject("AutoCADMap.Application.16.1")
    6,419
    BTW, Brennan, It would have been helpful if you included this info with your first post.
    LinkedIn
    Smile Re: Extracting Object Data into an Attributed Block
    Mr. Farrell helped me out - he suggested using an annotation template which extracted the object data information to a block. It was what I was looking for.
    Thanks again Mr. Farrell
  1. Replies: 2
    Last Post: 2008-02-12, 12:51 PM
  2. Replies: 0
    Last Post: 2008-02-07, 05:29 PM
  3. Extracting Object Data from Map 3D 2006
    By tim.ashton in forum VBA/COM Interop
    Last Post: 2007-05-23, 02:28 PM
  4. Extracting Object Data from entities in AutoCAD MAP
    By snviswanadha in forum AutoLISP
    Last Post: 2006-08-29, 05:15 AM
