Thread: Converting GCD files to DWG files
    2004-05
    Angry Converting GCD files to DWG files
    In the 1980's our Co. used Generic Cadd 6.1. We produced quantities of gcd files. We can read these files with VC Viewer but can not edit nor print them. Is there a way, or program, to convert these files to DWG Auto Cadd 2000 files ?
    Esps
    Moderator arcadia_x27's Avatar
    2015-10
    The 'Mill,Moncton, NB, Canada
    516
    Default Re: Converting GCD files to DWG files
    If you still have the GCD program you might try saving them as DXF files. or if the viewer can convert them to DXF you could read them in CAD that way. Only other thing i can think of is were those files compatibale with VersaCAD? I have a couple of old versions from the 80's that might read them
    2015-10
    516
    Follow up:
    I did some research on the web, Generic Cadd has a new release called General CADD that runs in Windows, it should be backward compatible with your older files and enable you to print them out. The company website is : http://www.genericcadd.com If you can also convert your old files to an EPS format than they could be read by Adobe Acrobat and you could save and print them as a PDF file. Hope this helps
  1. Converting Plot Files to PDF
    By jason.combs in forum Revit - Plotting/Printing/Exporting
    Last Post: 2008-07-03, 04:07 AM
  2. Converting plot files to dwg files
    By tcone00 in forum AutoCAD Plotting
    Last Post: 2007-11-24, 04:27 PM
  3. Converting DWG to PDF files in AutoCAD R14
    By loslobos44 in forum AutoCAD General
    Last Post: 2007-09-25, 03:47 PM
  4. Help in converting .pdf & .bmp files
    By m_joy in forum AutoCAD General
    Last Post: 2005-09-11, 01:08 PM
  5. Batch converting dwg files to dxf files?
    By CADKitty in forum AutoCAD General
    Last Post: 2005-08-09, 05:24 PM
