Thread: Tapered structural beam - how to make it?
    2005-11
    76
    Post Tapered structural beam - how to make it?
    How do I go about to create a tapered wide flange beam [e.g. 18" high on one end and 6" on the other]? I'm not acquainted with family creation/changing yet, so if that's what I need to do first I think I already found a tutorial on that.
    Axel
    P.S.: The attached picture is a Sketchup screenshot where I manipulated the Revit beam.
    All AUGI, all the time Justin Marchiel's Avatar
    2004-07
    Penticton, B.C., Canada
    954
    Default Re: Tapered structural beam - how to make it?
    yes using the family editor is supper important in revit. but you could create a blend that has the big size on one end and the small size on the other. this is faster and quicker then actually making a parametric family, but in the end, you will want to know how to make the family. And at that, once you understand the family editor, making this family is pretty easy.
    Justin
  1. Replies: 1
    Last Post: 2010-08-30, 05:46 AM
  2. Tapered Beam Mesh
    By charitidis in forum Robot Structural Analysis
    Last Post: 2010-07-15, 06:50 PM
  3. Tapered beam: Analytical vs physical model
    By smadsen100 in forum Revit Structure - General
    Last Post: 2010-04-16, 07:11 AM
  4. ASD 2010 - Tapered Beam design
    By neiledwigfern in forum AutoCAD Structural Detailing
    Last Post: 2009-06-02, 04:02 AM
  5. Tapered Wide Flange Beam
    By abink in forum Revit Architecture - Families
    Last Post: 2007-06-28, 01:03 PM
