Results 1 to 10 of 15
Thread: Bring back the grips!!
    AUGI Addict Mr Cory's Avatar
    2007-01
    Under a Rock over there
    1,006
    Default Bring back the grips!!
    Bring back the grips!! This could justbe a settings, for so tell me to shut up but bring back the grips for 3D Solids! its fustrating when a solid only has 1 grip and its sitting way out in mid air grr....
    2003-10
    San Francisco CA
    1,190
    Default Re: Bring back the grips!!
    Hi Cory,
    Grips work for me. Check to see if you have Enable Grips checked on the selection tab FORMAT - Options.
    Hope this helps,
    Scott Telthorst
    Quality Control Manager
    Helix Electric, Inc.
    www.helixelectric.com
    2007-01
    1,006
    Yeap its checked a
    2002-09
    Madison, WI
    5,688
    Have you tried mass elements? They have lots of grips and options to pull faces/split faces. And in the end you can convert them to solids if you like.
    2005-07
    2,356
    Also it may be that the objects were created in 2007 and saved back to 2004 file format.
    2007-01
    1,006
    3D solids created from mass elems are worse lol i made 1 and it only had 1 grip. I only use 07 a. Heres a pic of whats happening
    2003-10
    San Francisco CA
    1,190
    Quote Originally Posted by Mr Cory
    Hi Cory,
    I think mass elements may be the way to go considering the geometry you are trying to create. I drew a quick recreation of the drawing you posted with solids. Everything was fine until I unioned all of the geometry together. When I did this I only had one grip available just like you (See first picture). After converting it to a mass element a multitude of grips were available (See second picture)
    Hope this helps,
    Scott Telthorst
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    Once you create the mass element, select it, right click and choose convert to free form mass element.
    If that pic is a pic of an autocad 3D solid, I have no idea whats going on. You might try posting a question in the AutoCAD 3D forum for that stuff.
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    2007-01
    1,006
    I always turn my solids into mass elems eventy because of the ability of controling the display reps, but i learnt to use Vanilla so i prefer to work with solids but its just a pain to adapt them with only 1 grip.
    The soild i posted was created in ADT 07
    2015-12
    4,730
    If I make a simple 3D autocad solid using the dashboard in ADT 2007 with no acad cui loaded, the attached image shows I get grips for the cube I made.
    How did you make your 3D solid?
  1. Bring Back "Show"
    By Wish List System in forum NavisWorks - Wish List
    Last Post: 2014-11-13, 07:12 PM
  2. Bring back the Revit PDF Writer
    By Chad Smith in forum Revit Architecture - Wish List
    Last Post: 2006-04-12, 03:59 PM
  3. Bring back the functionality of EXPLODE
    By Jeff_M in forum API Wish List
    Last Post: 2005-11-22, 08:44 PM
  4. Bring back the Search path
    By Virago87 in forum AutoCAD Customization
    Last Post: 2005-02-18, 10:01 PM
  5. Bring to front/send to back??
    By Kelly@Laebon in forum Revit Architecture - General
    Last Post: 2004-04-30, 10:46 PM
