http://forums.augi.com/showthread.php?t=54505
Broken Section lines not selectable
Where Section lines have been “broken”, they should not be selectable along the invisible part of the line.
User settings remembered within session
Revit should remember all user settings on dialog boxes, within Revit session – eg. Import CAD files, Origin to Origin.
User settings remembered between sessions
Revit should remember more user settings on dialog boxes, between Revit session (user name parameters? system settings? – eg. We always want multiple copies ticked; we never want tag leaders ticked etc.
Longer menu lists
Drop down menu lists in dialog boxes should display more items – typically they only show six items
variable size properties dialog
Allow quick access to info lower down on Properties dialog box: eg. allow user to expand the size of the properties dialog box:
Wider field boxes for long nameslists
need wider boxes for long names - eg. Loc. Line for walls on options toolbar
Properties dialog remember settings
Revit to remember which parameter groups on properties dialog boxhave been collapsed by user - keep them hidden next time dialog is opened
Consistency on dialog check boxes
Consistency for clicking on check boxes / radio buttons. eg Filter dialog does not allow clicking on text to de/select the check box (it should), but other dialogs do - allows for quicker mouse-work.
Yes, and what's hidden is the top of the list as opposed to the bottom. That's very anti-windows convention and counterintuitive.Originally Posted by twaldock
Autodesk is putting someone right on it:
http://autodesk.recruitmax.com/eng/c...ourceID=Indeed
"Intermediate User Interaction Designer...
• Assist in creation and maintenance of interaction and style guides for UI ...
• Provide expertise in user research activities including persona creation, heuristic evaluation, interviews, and site visits including ethnographic observation and/or CI ..."
