Ogre
Thanks!!! I have been working on that since I got back from AU...
Well the VPORTS layer is actually so we can get to them when we need them...We turn it off and on...I have no problem with the 0 layer, but when you have multiple viewports, it is hard to get things straight...
Really I am the only "drafter" here...Everyone else helps me out with the easy drawings...Most of our stuff is templates, so there is not that much drawing involved...Except when we get something that is not standard or one of our products that is used in a different way than usual...
We work with Arch & Theatrical dimming...I am starting to develop a system where wires and the controls that use those wires are on the same layer...That way if I have an theater with house lights and theatrical lights using the same dimming racks, I can freeze the Arch controls and focus on the Theatrical and vice versa...But that is a personal thing that I am trying out...The main designer likes to use colors, but he is kind of Old School...I try to combine the 2...
As for getting rid of old layers, if they are not on the purge dialog, then they are most likely nested within blocks...Truthfully you have a long and tedious task ahead and you sir, I do not envy...The only way I can think of is to edit each of the blocks in the drawing...With the Blockeditor it is actually easy to manipulate bunches within the same drawing...
If you really want to fix up the drawings, come in on a few weekends and do it...I would not recommend doing it during business hours, unless you have a big chunk of spare time...It will take a while...
If you have any overlapping lines and some such, I find the overkill command has wonderful results...However, depending on the size of the drawing, it may take a while...I have my machine running for over an hour when I ran that command...
