Results 1 to 10 of 12
Thread: TIP: VBA command wrappers for lisp
    6,417
    Default TIP: VBA command wrappers for lisp
    I have a menu which includes providing wrapper functions for many vba routines. The attached code is not a complete lisp function, but a portion of an mnl that automates creating "C:" style defuns for my vba routines. When I add a new vba sub, all I have to do is add the text name to an array.
    The mnl uses (vl-vbaload) to load the dvb containing the subs. The RunMacro method is used rather than (vla-runmacro) because many of my subs make use of the PickfirstSelectionSet, which gets cleared when called from lisp. You can change the consctuctor to utilize vbarun if you wish. The main point here is to minimize maintenance so as not to have dozens of defun's.
    LinkedIn
    2015-08
    16
    Default Re: TIP: VBA command wrappers for lisp
    sweet! Great tip.
    6,417
    Thank you.
    LinkedIn
    AUGI Addict fixo's Avatar
    2005-05
    Pietari, Venäjä
    1,269
    Quote Originally Posted by brett.burling
    sweet! Great tip.
    Agreed, very nice one
    ~'J'~
    2015-08
    16
    Just got upgraded to AutoCAD 2008 and the "wrapper" doesn't seem to work anymore. Anyone else had troubles??
    6,417
    There's nothing in there that should be specific to a version. Check your installation, i.e. support paths, cui, etc. Make sure everythings getting loaded properly.
    LinkedIn
    2015-08
    16
    Umm..
    Checked the CUI and the lisp file is definitely being loaded, still no luck.
    If i open the lisp file and change the wrapper to the"old way" of doing things....
    (defun c:BGESECTIONMARK()
    (vl-load-com)(vla-runmacro (vlax-get-acad-object) "BGESECTIONMARK")
    (defun c:BGESECTIONTITLE()
    (vl-load-com)(vla-runmacro (vlax-get-acad-object) "BGESECTIONTITLE")
    It works fine. My wrapper code is attached...
    6,417
    I noticed you added (vl-load-com) to each of your commands, but its not in the attached lisp.
    LinkedIn
    6,417
    I also, should mention that using this tip executed the macro in the document context, whereas vl-vbarun and VBARUN run the macro in the application context. The result is that you may run into a problem if the macro needs to hide the a modal form to get user input. Since the macro is running in the document context, the application cannot respond to mouse events, i.e. the cursor dissapears.
    LinkedIn
    All AUGI, all the time zoomharis's Avatar
    2005-02
    Abu Dhabi (Native-India)
    506
    Thanks for the code, Ed Jobe. It's really helpful for me as I use so many macros in my application. By the way, I would like to use command alias differently from the command name. For example, I normally use a command alias 'ALT' for the macro 'AlignText'. How to incorporate this in your program?. I am sorry. I know only a few things in lisp.
  1. Replies: 3
    Last Post: 2009-10-22, 10:19 PM
  2. Mtext Command in Lisp
    By bowtle in forum AutoLISP
    Last Post: 2009-01-12, 05:47 PM
  3. TableStyle command in lisp
    By am4soft in forum AutoLISP
    Last Post: 2009-01-11, 02:28 PM
  4. torient command in lisp
    By mbergink in forum AutoLISP
    Last Post: 2008-12-24, 04:15 AM
  5. Help starting a LISP command
    By gurudas.ku in forum AutoLISP
    Last Post: 2006-12-15, 05:00 AM
