Results 1 to 10 of 11
Thread: Help rewriting some code - create a file list and write it to a text file
    2006-04
    466
    Default Help rewriting some code - create a file list and write it to a text file
    I wrote this program and lost the code.
    I am hoping maybe some of you guys more versed in Visual Basic would do it with ease.
    Attached is the EXE. It just needs to make a file list and write it to a text file.
    For the current program to function, LOOKDB.LDB must be in C:\Wat
    AUGI Addict fixo's Avatar
    2005-05
    Pietari, Venäjä
    1,269
    Default Re: Help rewriting some code - create a file list and write it to a text file
    I don't see no code there
    just a list of files:
    C:\acad stuff\zip8\CLNOUT.dwg
    C:\acad stuff\zip8\CTCHBSN.dwg
    C:\acad stuff\zip8\CURBGUT.dwg
    C:\acad stuff\zip8\CURBGUT2.dwg
    C:\acad stuff\civildetails\51-104.dwg
    C:\acad stuff\civildetails\51-105.dwg
    C:\acad stuff\civildetails\51-11.dwg
    C:\acad stuff\civildetails\51-112.dwg
    ~'J'~
    2005-05
    Pietari, Venäjä
    1,269
    Okay, here is slightly adapted
    listing by Ken Puls
    Option Explicit
    '' based on listing written by Ken Puls (www.exelguru.ca)
    Sub TextStreamTest()
        Const ForReading = 1, ForWriting = 2, ForAppending = 3
        Dim fso As Object
        Dim fdw As Object, sdw As Object
        Dim fdr As Object, sdr As Object
        Dim strText As String
         'create file sysytem object
        Set fso = CreateObject("Scripting.FileSystemObject")
         'get file to read and open text stream
        Set fdr = fso.GetFile("C:\Wat\Lookdb.ldb")
        Set sdr = fdr.OpenAsTextStream(ForReading, False)
         'create new file to write to
        fso.CreateTextFile ("C:\Wat\Lookdb.txt")
        Set fdw = fso.GetFile("C:\Wat\Lookdb.txt")
        Set sdw = fdw.OpenAsTextStream(ForAppending, False)
         'iterate through the end of first file
        Do Until sdr.AtEndOfStream
            'read string from the first file
            strText = sdr.ReadLine & vbNewLine '<--added carriage return to jump on the next line
            'write to the second one
            sdw.Write strText
        Loop
        'close both files and clean up
        sdr.Close
        sdw.Close
        Set sdr = Nothing
        Set sdw = Nothing
        Set fdr = Nothing
        Set fdw = Nothing
        Set fso = Nothing
    End Sub
    ~'J'~
    2006-04
    466
    When I originally created the code I used some projects found on vbcode.com and spliced them together. Basically I was hoping you guys could use LOOKDB.EXE to recreate the code. I need the recreated code so I can create READDB.EXE to select multiple text documents. I need a complete project.
    6,397
    Apparently you don't have any idea what it would take to decompile an exe, an read the machine code. It would be far easier for you to rewrite it.
    AUGI Addict MikeJarosz's Avatar
    2015-10
    New York NY
    1,497
    Quote Originally Posted by aaronic_abacus
    There was a thread here some time back that dealt with editing .exe files. This is heavy stuff. Check this out:
    http://forums.augi.com/showthread.php?t=44445
    2006-04
    466
    I'm not really looking to decompile the EXE, I was hoping the project could be written by example(LOOKDB.EXE) alone.
    6,397
    Then why would you expect someone else to do it for you?
    2006-04
    466
    It's very simple, if you look at LOOKDB.EXE, It just creates a list of files in an ASCII text file(one file per line).
    No interaction with autocad or anything.
    2015-10
    New York NY
    1,497
    Quote Originally Posted by MikeJarosz View Post
    Since I wrote this reply, I attended an ADN developer camp in Boston. Jeremy Tammik, one of the instructors, demonstrated a program that went beyond decompilation of an .exe file into assembler and actually created source code in VB and C#!!! From my class notes I found this link on Google. I have not had time to check this out, but I was impressed by Jeremy's demo!
    http://www.aisto.com/roeder/dotnet/
    Warning: be sure to read the discussion the first link refers to. This is still heavy stuff....
  1. Create a list of drawings and write them to a text file
    By aaronic_abacus in forum AutoLISP
    Last Post: 2014-11-26, 07:36 AM
  2. 2014: Revit reporting Central File is not available, no one else is in file, can't save, won't create local file
    By patricks in forum Revit - Worksharing/Worksets/Revit Server
    Last Post: 2013-10-03, 10:31 PM
  3. File write problem with NWD- /NWC-file type
    By bma in forum NavisWorks - General
    Last Post: 2010-08-31, 09:43 PM
  4. Write usernames to text file
    By mikelf in forum AutoLISP
    Last Post: 2009-01-31, 09:33 PM
  5. Read / Write To Text File
    By caddog71 in forum VBA/COM Interop
    Last Post: 2008-05-27, 06:40 PM
