Results 1 to 7 of 7
Thread: Export or Save DWG file to .STEP or .IGES
    2007-02
    12
    Question Export or Save DWG file to .STEP or .IGES
    Ok I need help saving or exporting .DWG to .step or .iges file. I do have a copy of Inventor Pro 2006. However I am not yet familiar w/the software. I tried to import the DWG file into Inventor but the main componets were incomplete. I saw somewhere that if you exploded the image to 2D that it would open in Inventor. I did that However everything was scattered so that does me absolutely no good. Is there any way to do this with Mechanical Desktop. If someone could help me I would greatley appreciate any help. What would happen if I just renamed the file as a .step or .iges other than absolutely nothing????
    Thanks
    JOHN
    0,0,0 The Origin
    8,570
    Default Re: Export or Save DWG file to .STEP or .IGES
    AFAIK, step and iges are 3d formats so "exploding to 2d" won't help.
    Vanilla AutoCAD does not create these formats so I think you need to persevere with Inventor or Mechancial Desktop.
    Renaming a file will achieve nothing, I'm afraid.
    2007-02
    12
    I do have a copy of mechanical desk top 2006 didn't figure there was a difference considering upon install it prompted me for which icon I wanted to display as quick link mechanical or autocad
    0,0,0 The Origin
    8,570
    I believe MDT 2006 has export to iges. Could be wrong though.
    2007-02
    12
    Quote Originally Posted by jaberwok
    I'll have to re-install it right now using the 2007 demo
    Manufacturing Moderator jonathan.landeros's Avatar
    2005-03
    Los Angeles County, Ca.
    440
    Quote Originally Posted by forums.133238
    ACAD-M can export IGES by going to File>Export IGES.
    MDT can also export STEP by going to the same location (File>Export and choosing STEP).
    Hope this helps!
    Jonathan Landeros
    KETIV Technologies
    Orange County, California.
    I've got a blog: www.inventor-tales.blogspot.com
    “We have now left Reason and Sanity Junction.Next stop, Looneyville.” -Bob the Skull in the Dresden Files
    2007-02
    12
    Quote Originally Posted by jonathan.landeros
    Hope this helps!
    Thanks helps alot still pretty new to this
  1. Shrinkwrap save as step/iges file as solid
    Last Post: 2012-08-23, 01:27 PM
  2. Converting DWG to either IGES or STEP files
    By antoine.autruffe780653 in forum AutoCAD General
    Last Post: 2012-01-20, 09:27 PM
  3. IGES and STEP support to AutoCAD
    Last Post: 2010-07-08, 06:24 PM
  4. Export to IGES and_or STEP format
    By Mdunbar in forum AutoCAD 3D (2006 or below)
    Last Post: 2007-02-08, 07:53 PM
  5. Replies: 0
    Last Post: 2005-11-23, 01:22 PM
