Results 1 to 6 of 6
Thread: Nested Fields - Convert units for Northings/Eastings?
    Active Member keelay711's Avatar
    2004-11
    San Diego, CA
    84
    Question Nested Fields - Convert units for Northings/Eastings?
    Thank you for taking the time to read this.
    I have a block utilizing fields to display its position coordinates (similar to many others, as noted in these forums). My problem lies in that I want to display the northings/eastings in decimal feet, per our clients wishes, but our drawing geometry is all based in inch units.
    I have attempted to nest fields in order to make this happen. The ATT value is a formula field which references (position field / 12). The position field has the format properties of only Y coordinate, 2 decimal places. There is no corresponding format option on the formula field. Currently, my output looks as follows:
    000000.0000, 000000.0000, 000000.0000
    X Y Z are all displayed, and the formatting does not reflect the 2 decimal precision.
    Is there a way to make this work?
    Administrator Opie's Avatar
    2002-01
    jUSt Here (a lot)
    9,105
    Default Re: Nested Fields - Convert units for Northings/Eastings?
    When working on your formula, have you used the Evaluate button? This will provide additional selections you can use to further define your fields.
    2004-11
    San Diego, CA
    84
    I have looked at the evaluate button, but I see no additional options to it. The following red portion is what changes with each evaluation.
    %<\AcExpr (%<\_FldPtr 2107814136>%/12) \f "%lu2%pr2">%
    My basic formula is this:
    InsertionPoint/12
    Is there some coding I can add to the formula to make it do what I want?
    2002-01
    jUSt Here (a lot)
    9,105
    Are you using Block Place Holder Fields?
    Can you post a copy of your block?
    2004-11
    San Diego, CA
    84
    Here is the block with the two variants of the fields.
    2006-09
    iran
    9
    Thumbs up Re: Nested Fields - Convert units for Northings/Eastings?
    Quote Originally Posted by keelay711
    HI.FILE IS TRUE
  1. How to convert SI Units l/h instead of l/s in REVIT MEP 2010??
    By ncostab in forum Revit MEP - General
    Last Post: 2010-03-09, 01:17 PM
  2. Convert Civil drawings using decimal units into Arch. units
    By tlarocco in forum AutoCAD Civil 3D - General
    Last Post: 2006-07-17, 05:52 PM
  3. How to convert units according to Encient style?
    By oshenic2004 in forum AutoCAD Customization
    Last Post: 2005-02-18, 04:13 PM
  4. Block for Northings/Eastings
    By keelay711 in forum AutoCAD General
    Last Post: 2005-02-01, 08:23 PM
  5. How do you convert units inside Revit??
    By Richard McCarthy in forum Revit Architecture - General
    Last Post: 2004-10-25, 02:52 PM
