Results 1 to 7 of 7
Thread: AutoCAD LT 2007 - OLE Objects plot as black boxes
    2007-02
    Default AutoCAD LT 2007 - OLE Objects plot as black boxes
    Has anyone ran into a problem printing a drawing with an OLE file embedded? When using Multi-batch, I keep getting black boxes instead of the table I've inserted. I am using 2007 LT, 2007Excel, Multi-batch 8.0...
    Scott
    13,656
    Default Re: AutoCAD LT 2007 - OLE Objects plot as black boxes
    Hi
    For starters, you may wish to browse / review the information found in the following thread...
    OLE (eg Excel) Objects within drawing file not Plotting correctly
    Have a good one, Mike
    2007-02
    Thanks. I think I read all of those before posting though
    I think it is a Multi-Batch problem. I can print correctly through the Autocad plot menu. It's when I send the entire set with Multi-Batch that I get the black boxes.
    2007-04
    4
    I keep getting black boxes when i try to plot an ole object to a dwf either through publishing or plotting.
    2005-05
    6
    Has anyone ever found a solution to this one? I am having the same problem, (Excel files printing as black boxes).
    2007-11
    Minneapolis
    29
    I would check the properties of the OLE. Just right click on the OLE to view the properties optin. Then look in the Misc. catagory for the plot quality. Make sure it is on Monochrome.
    2005-05
    6
    That was it!, Thaks alot for the help.
  1. Replies: 7
    Last Post: 2007-05-30, 12:46 PM
  2. Replies: 2
    Last Post: 2007-04-07, 06:45 PM
  3. Replies: 4
    Last Post: 2007-03-12, 11:48 AM
  4. AutoCAD 2007 - Plot top view of a 3D Object showing hidden lines in black
    By keith.43062 in forum AutoCAD 3D (2007 and above)
    Last Post: 2006-12-16, 08:47 AM
  5. AutoCAd 2007 - Background is Grey even though I have it set to Black
    By robert.1.hall72202 in forum AutoCAD General
    Last Post: 2006-05-31, 12:28 PM
