Then what about a shortcut of the item on the desktop?Originally Posted by david_peterson
nevermind. that just makes a new dwgOriginally Posted by Steve_Bennett
That only works for the dwg, it actions the same as qnew if you open a template in explorer
Now there's an outside the box idea. Create an icon on your desktop set to open the template that you want to modify. Then you can simply pick on the little windows "show desktop" icon and you can open it directly. Only problem there is waiting for it to launch another session of ADT. I'm still thinking that there's a way around this using a basic button or a right click maybe that acts like the "open x-ref" command but you don't have to select what you want to open because you already know that.Originally Posted by Steve_Bennett
Will this post, "Opening new template in LISP" help?
Thanks Opie, Looks like that one should work.Originally Posted by Opie
Yeah, that would work. Just tested it. You can only have 1 dwg open when running the command in that lisp that rkmcswain posted.Originally Posted by david_peterson
Sweet cheers guys!! Thanx for all your help!
yes, but you should try his last postOriginally Posted by Steve_Bennett
(vl-load-com) with
(vla-Add (vla-get-Documents (vlax-get-acad-object)) "acad.dwt")
: ) Happy Computing !
kennet
Grr is it just me or does it flick back to the drawing you had open?
