Thread: Structural - Steel I Beam
    2006-03
    15
    Arrow Structural - Steel I Beam
    Hello everyone
    There are some DB in A.D.T. you can borrow, they work in normal Autocad
    but the "I" beam sizes are very IFFFFy
    I have re-jigged one to suit British I beam sizes however I have lost the connection
    to the pull down menu showing the sizes.
    can anyone help
    Hevgee
    hopefully the dwg is attached
    Retired Forum Staff Rico's Avatar
    2005-06
    In the hospital cuz of my fever for more cowbell
    1,828
    Default Re: Structural - Steel I Beam
    Quote Originally Posted by hevgee
    Hello everyone
    can anyone help
    Hevgee
    did you know that AutoCAD comes pre-loaded with both Imperial and Metric versions of the I beams you did? They are found under:
    C:\Program Files\AutoCAD 2006\Sample\Dynamic Blocks
    However if you use ADT, the folder structure might be a bit different.
    [SIGPIC][/SIGPIC]
    Return of the Cowbell
    Active Member philip.107935's Avatar
    2006-03
    79
    Hello everyone
    can anyone help
    Hevgee
    Hi have a try of my one, its' all tabled so all you need to do is change the lookup tables to suit your sizes, they are currently metric from NZ
  1. Replies: 2
    Last Post: 2016-11-08, 01:29 PM
  2. 2014: Revit Out of the Box Structural Steel Beam Families
    By Limbatus in forum Revit Architecture - Families
    Last Post: 2014-05-26, 04:33 AM
  3. Replies: 5
    Last Post: 2009-05-11, 07:46 PM
  4. Concrete encased structural steel beam
    By pinky in forum Revit Architecture - General
    Last Post: 2006-09-22, 03:53 PM
  5. Concrete encased structural steel beam
    By pinky in forum Revit Architecture - Families
    Last Post: 2006-09-21, 10:25 PM
