Results 1 to 6 of 6
Thread: Using decimal units in lisp while ACAD is set for Arch
    2015-12
    385
    Default Using decimal units in lisp while ACAD is set for Arch
    Hello all,
    I wrote the code below and it works pretty well, the problem I am running into is that I have to switch my units to decimal and then switch the decimal place to "0" so that the text appears correctly. (notn feet and inches)
    Is there a way within a lisp to tell ACAD to keep the units decimal and then once the command i sthrough go back to arch?
    Thank you all in advance,
    Andre
    (defun c:cfm (/ currlay sqft inspt ocfmpersqft curros)
      (command "undo" "begin")
      (setvar "CMDECHO" 0)
      (setq curros (getvar "osmode"))
      (setvar "osmode" 64)
      (if (not cfmpersqft) (setq cfmpersqft (+ 0 0)))
      (setq ocfmpersqft cfmpersqft)
      (setq cfmpreview (rtos ocfmpersqft))
      (if
        (= (setq cfmpersqft (getreal (strcat "\enter CFM per sq ft number:  <" cfmpreview ">:"))) nil)
        (setq cfmpersqft ocfmpersqft)
      (setq currlay (getvar "Clayer"))
      (setq sqft (getreal "\nenter room square foot: "))
      (setvar "clayer" "M-QUCO-CHCK")
      (command ".text" "j" "mc" pause "2.25" 0 (strcat (rtos (* sqft cfmpersqft))""))
      (setq roomcfm (* sqft cfmpersqft))
      (setvar "clayer" currlay)
      (setvar "osmode" curros)
      (command "undo" "end")
      (setvar "CMDECHO" 1)
      (princ (strcat roomcfm))
      (princ))
    2005-08
    1,043
    Default Re: Using decimal units in lisp while ACAD is set for Arch
    Look into 'rtos'. You call it plenty of times, but you don't give it all the arguments it can take.
    2015-12
    385
    Will look into it this evening, thanks for the help thus far
    AUGI Addict kennet.sjoberg's Avatar
    2002-05
    1,707
    cvunit ?
    : ) Happy computing !
    kennet
    2015-08
    263
     (command ".text" "j" "mc" pause "2.25" 0 (strcat (rtos (* sqft cfmpersqft) 2 0)""))
    Regards,
    Abdul Huck
    I could stop if I wanted to kpblc2000's Avatar
    2006-09
    212
    I think the better way is to use construction like
    (if (= 0 (tblsearch "style" (getvar "textstyle")))
      (command "_.text"
               "_j"
               "_mc"
               pause
               2.25
               0.
               (strcat (rtos (* sqft cfmpersqft) 2 0) "")
               ) ;_ end of command
      (command "_.text"
               "_j"
               "_mc"
               pause
               ) ;_ end of command
      ) ;_ end of if
    It seems more universally.
  1. Lisp Routine: Decimal to Surveyor Units
    By Firmso in forum AutoCAD Customization
    Last Post: 2009-02-20, 09:31 PM
  2. Replies: 4
    Last Post: 2007-12-10, 07:03 PM
  3. Replies: 12
    Last Post: 2006-12-14, 09:04 PM
  4. Convert Civil drawings using decimal units into Arch. units
    By tlarocco in forum AutoCAD Civil 3D - General
    Last Post: 2006-07-17, 05:52 PM
  5. Replies: 2
    Last Post: 2006-01-31, 08:12 PM
