Hi all
I recently got a problem with ADT 2006. Just started 5 days ago.
When starting up ADT 2006, everything is fine. But if I try to save/save as I get 2 errors and the ADT2006 closes down.
Error 1 is:
Microsoft Visual C++ Runtime Library
Runtime Error!
Program: ...ogram Files\Autodesk Architectural Desktop 2006\acad.exe
This application has requested the Runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
Then the only option is to press "OK" now right after the 2. error occurs.
Error 2 is:
AutoCad Error Aborting
FATAL ERROR: Unhandled e0434f4dh Exception at 7c812a5bh
Then the only option is to press "OK" now ADT 2006 simply closes.
ADT 2006 is fully updated.
The computer is a:
IBM Laptop T60 running XP PRO (SP2), 2 GB RAM, GFC: X1400 512mb.
On the Laptop is ADT 2007 and it works fine ... and Revit 9.1 also works fine... After some troubleshooting I started to uninstall Mircosoft .NET Framework 2.0 and 1 and Error 2 disappeared...but even if I reinstall or repair ADT2006, Error 1 is still there.
