Results 1 to 7 of 7
Thread: Is there a way to reset the tool palettes without having to restart AutoCAD?
    2004-07
    Detroit Michigan
    2,508
    Default Is there a way to reset the tool palettes without having to restart AutoCAD?
    When switching profiles, I often see the tool palletes disappear.
    I should see the tool palletes associated with the profile I have selected.
    Is there a way to reset the tool palletes without having to restart AutoCad?
    13,657
    Default Re: Is there a way to reset the tool palettes without having to restart AutoCAD?
    Hi
    Could you please explain some more, as currently I do not fully understand the issue / problem you are trying to resolve. Sorry.
    Have a good one, Mike
    2004-07
    Detroit Michigan
    2,508
    I switch from one user profile to another and the tool palletes do not appear.
    All I get is an empty tool pallete. If I close and restart AutoCad, then
    all the tool palletes appear.
    I should be able to switch profiles and have everything in working order.
    I may just be blowing off some steam because I do not see any other
    fix than launching profiles from desktop shortcuts. Switching profiles
    while in AutoCad does not seem to be working quite as I had expected.
    13,657
    Hi
    Ok! Look at setting up Workspaces and switching between them as needed.
    All AUGI, all the time Mlabell's Avatar
    2004-12
    Toledo, OH
    513
    Quote Originally Posted by Robert.Hall
    You may want to create a macro to reload the tool palette if it doesn't work as Mike suggested. Also maybe make a toolbar for the different tool palettes for easy switching.
    Here is one of the the macros I use to switch between my palettes
    ^C^C*_toolpalettepath;"C:/Documents and Settings/YOURNAMEHERE/Application Data/Autodesk/AutoCAD 2007/R17.0/enu/support/ToolPalette";
    2004-07
    Detroit Michigan
    2,508
    Quote Originally Posted by marklabell
    Good suggestion. I hadn't given that much thought.
    I suppose I could load the palette separate from the profile if I have
    a dysfunctional profile.
    2004-07
    Detroit Michigan
    2,508
    Quote Originally Posted by Mike.Perry
    Hi
    Good suggestion. I will have to try workspaces again.
    I had them set up once, but rarely swithced between them.
    Workspaces may be easier to handle than profiles.
  1. CP223-1: Trick Up Your Tool Palettes: How to Make Your Tool Palettes Do Even More!
    Last Post: 2015-08-07, 05:17 PM
  2. Replies: 2
    Last Post: 2006-10-25, 07:29 PM
  3. Replies: 1
    Last Post: 2006-05-14, 06:00 PM
  4. Replies: 2
    Last Post: 2006-05-12, 01:40 PM
  5. AutoCAD 2005 tool palettes
    By Nick.Nemechek71583 in forum AutoCAD General
    Last Post: 2004-08-27, 12:14 PM
