how do i center the mullions in between the curtain grid, whenever i insert the mullions, they are offset from the center of the curtain wall
Look at the properties of the mullion.
Scott D. Brown, AIA
BECK
i did, but it only asks if it is parallel or perpendicular to the ground - this still does not place the mullion in the MIDDLE of the curtain wall - it has it positioned at the end of the mullion
Since the mullion is "attach" a gridline. It,s that grid line that needs to be in the middle. TAB to select it and use temporary dimension to place it in the middle
the gridline is centered, however, the panels are not - i am trying to center the panels within the mullions
Can you post the file or an image to illustrate the problem ?
not really. but put it this way, when you draw a typicall mullion and glass in plan (5"), you would see a mullion with a 1" glass in between it on each side. i am not able to position the mullion so that it is directly centered on the glass. what is the process of doing this? i appreciate your help
also, how do you insert a curtain wall door, without changing the glass panel to a wall first?
Can you simply post a screenshot. hit the print screen button of your keyboard and paste in Words. add comment and post
You need to load a curtain wall family and simply replace the panel with that family. You can find some OOTB in the door family folderOriginally Posted by dhurtubise
