Thread: Multistory stairs prevent moving building up
    2006-12
    5
    Default Multistory stairs prevent moving building up
    I'm trying to move my building up, so that First Floor elevation becomes 100'-0", instead of the 0'-0". But when I change the height in the elevation marker, I get this warning: "Multistory top level must be above the stair/ramp top and bottom levels." I have a three story building with a multistory stair that runs from 1st to 2nd floor and from 2nd floor to 3rd floor. In the multistory stair, the Base Level is set to First Floor, the Top Level is set to Second Floor, and the Multistory top level is set to Third Floor Plan. I don't understand why the stair is preventing the building from moving up.
    2005-07
    Somewhere in the BIM world
    3,792
    Default Re: Multistory stairs prevent moving building up
    Either relocate or lock dimensions between levels and them change the level height
  1. Multistory stairs tread/riser numbers
    Last Post: 2019-04-02, 08:31 AM
  2. 2014: Prevent tags from moving with object
    By gascad14 in forum Revit MEP - General
    Last Post: 2014-02-20, 08:20 AM
  3. Issue with railing on Multistory stairs? Revit 2013
    By Baldwin_4-6-0 in forum Revit Architecture - General
    Last Post: 2014-02-19, 09:56 AM
  4. Revit 2013 Multistory stairs
    By rob.127056 in forum Revit Architecture - General
    Last Post: 2014-02-11, 11:26 AM
  5. Replies: 0
    Last Post: 2013-04-17, 04:15 AM
