I'm not an expert but have you looked at blipmode sys variable?
I know I am resurrecting an ancient post, but incase someone else comes across this, here is what I found. When placing points in the DEFPOINTS system layer, they would always show up as a dot, no matter what my settings were. Hope this helps.
Since you brought it up NEVER use the DEFPOINTS system layer whose sole purpose it for dimension node points.
Issues:
TechBeat Tuesday – AutoCAD Tip #3: Two Reasons NOT to Use the Defpoints Layer https://land8.com/techbeat-tuesday-a...fpoints-layer/
Unable to delete "$AUDIT-BAD-LAYER" layers https://knowledge.autodesk.com/suppo...ER-layers.html
Cannot select objects on Defpoints layer when Layer 0 is off in AutoCAD https://knowledge.autodesk.com/suppo...n-AutoCAD.html
Users have actually put objects on DEFPOINTS system layer and later erased everything on that layer not realizing what that did to all the drawings dimensions.
