Thread: Q - Inserting Blocks through Tool Palettes
    Active Member zorroxxxx's Avatar
    2002-12
    93
    Question Q - Inserting Blocks through Tool Palettes
    Hi Chris,
    This may be a real DB newbie question. The "Windsor" DB I posted actually included the Title Block. I have dragged the DB onto a toolpallet from the dwg I posted and it works fine when I put the block in a new drawing. But if a do "Insert" @ the command line and then insert the DB, there are no "Dynamic" capabilities. Is this because of the Title Block?
    When you create DBs, should they be done without a Title Block?
    Hope all that made sense.
    Gary
    AUGI Addict .chad's Avatar
    2006-04
    is it lunch time yet?
    1,129
    Default Re: Q - Inserting Blocks through Tool Palettes
    Quote Originally Posted by zorroxxxx
    Hi Chris,
    Gary
    i havent looked at it - but my guess is that when you insert it is inserting the DB and title block, creating a nested block. exploding once should take care of that.
    This aggression will not stand. Man.
    2002-12
    93
    Red face Re: Q - Inserting Blocks through Tool Palettes
    Hi Chad,
    Yes, exploding once worked.
    So I guess I need to know how to create a DB correctly without including the Title Block.
    Gary
    Retired Forum Staff Chris.N's Avatar
    2001-12
    Rochester, MN
    2,561
    Hi Chad,
    Gary
    gary, we had a short discussion in here on that very subject.
    S&D DB Sharing Forum
    2002-12
    93
    Talking Re: Q - Inserting Blocks through Tool Palettes
    I have it working correctly now.
    Thanks
    Gary
  1. tool palettes/ blocks icon
    By aswalker in forum AutoCAD Customization
    Last Post: 2007-12-03, 08:36 PM
  2. Replies: 1
    Last Post: 2006-12-12, 09:16 AM
  3. Lisp code when inserting blocks from tool palettes
    By IanR in forum AutoCAD Wish List
    Last Post: 2006-06-02, 12:49 PM
  4. Inserting Blocks into Tool Palettes
    By stephen.coff in forum AutoCAD Customization
    Last Post: 2005-12-16, 01:29 PM
  5. Blocks in Tool Palettes
    By Li'l Crys in forum AutoCAD Customization
    Last Post: 2005-01-18, 07:26 PM
