Results 1 to 10 of 15
Thread: Working with LDT 2006 Contours in ADT 2006
    2007-02
    Seattle, WA
    7
    Default Working with LDT 2006 Contours in ADT 2006
    We are having issues when we create contours in Land Desktop 2006 and then open the drawing in Architectural Desktop 2006 the contours end up being square boxes.
    Has anyone seen this before and/or know how to fix it?
    Thanks
    Member alexmirb's Avatar
    2007-01
    45
    Default Re: Working with LDT 2006 Contours in ADT 2006
    Maybe you have to go into this page:
    http://usa.autodesk.com/adsk/servlet...linkID=2475161
    And download the object enabler accords to your software, but I'm not sure if this fix your problem.
    2007-02
    Seattle, WA
    7
    The test machine I am using has all the major Object enablers and still the same issue as others with no object enablers.
    Administrator richard.binning's Avatar
    2015-12
    In the foothills of the appalachians
    2,261
    try forcing the (objrelupdate) the objects to update. If this doesn't work, then you need to reinstall your object enablers.
    Richard
    P.S. I support the following: LDT, ABS, ADT, CIVIL3D, REVIT Bldg, REVIT Systems, REVIT Structures, Raster Design, Survey and a few other apps for good measure.
    2007-02
    Seattle, WA
    7
    I tried using the command you suggested and it didnt do anything to help with the problem
    However upon closer inspection of the drawings I noticed that there is some Aec text attached to every contour box.
    I attached a picture to show this
    Is there an object enabler for Civil Design and Civil Survey?
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    Quote Originally Posted by skrasovsky
    Have you tried THIS ONE and THIS ONE?
    2007-02
    Seattle, WA
    7
    Yes I have them both installed and I have reinstalled them and they still do not help...
    Lost
    1,473
    Can you post the drawing (take out logos etc that you don't want others to see)? Maybe we can troubleshoot it that way.
    Lost
    1,473
    Also, what are your PROXYGRAPHICS and PROXYSHOW system variables set to?
    2007-02
    Seattle, WA
    7
    Well I was checking what proxygraphics was set to and noticed that under Demand load ObjectARX apps it was set to command invoke. I set it to object detect and command invoke and it works everything shows up as it should.
    Thanks all for the help.
  1. autocad 2006 -- commands not working
    By brenda.132460 in forum AutoCAD General
    Last Post: 2010-10-19, 08:42 PM
  2. 2006 Publisher Import not working
    By ledridge.146389 in forum Hardware
    Last Post: 2007-10-09, 07:56 PM
  3. SDI appears to not be working in AutoCAD Map 3D 2006
    By preddy08 in forum AutoCAD Map 3D - General
    Last Post: 2007-04-09, 04:07 PM
  4. Old VBa not working in AutoCAD 2006
    By ramonc in forum VBA/COM Interop
    Last Post: 2006-05-18, 03:59 PM
  5. AutoCAD 2006 - F12 key not working
    By nadserial in forum AutoCAD General
    Last Post: 2005-04-01, 07:06 AM
