Thread: Export Object data to a text file?
    2005-02
    12
    Question Export Object data to a text file?
    Is there away to export the data listed in the properties box to a text file?
    If I list an arc, it gives me limited info. however the properties box gives me far more information regarding geometry which I would like to export to a text file
    2004-07
    Detroit Michigan
    2,508
    Default Re: Export Object data to a text file?
    Good question.
    What else do you want?
    All the mathmatical stuff seems to be there when I do a list on an arc.
    2005-02
    12
    The properties dialogue box quotes the start, end and centre Z values. The list command only gives you the arc centre Z value.
  1. Ability to put object parameters/data in text
    Last Post: 2013-03-06, 09:05 AM
  2. Problem about object data value (import from DGN file)
    By supphachai.s in forum AutoCAD Map 3D - General
    Last Post: 2009-02-16, 04:36 AM
  3. Object Data to Text Label
    By m.storey in forum AutoCAD Map 3D - General
    Last Post: 2006-09-20, 07:11 AM
  4. text object data
    By roy.70844 in forum AutoCAD Map 3D - General
    Last Post: 2006-06-08, 10:23 AM
  5. .shp file object data to CAD properties
    By aws.89861 in forum AutoCAD Map 3D - General
    Last Post: 2005-07-20, 05:23 PM
