Thread: Insert Saved View results in - Access Violation. Unable to open drawing.
    2003-11
    Ashland, Kentucky
    64
    Default Insert Saved View results in - Access Violation. Unable to open drawing.
    I have drawing that I am trying to insert saved views into via the sheet set manager. The view is reflected in the resource drawing tab of the SSM. When I go to insert the saved view in gives me an "Access Violation. Unable to open drawing." error. It doesn't make any sense, at least to me. The saved views are in the drawing that I currently have open and am working in. Any thoughts or suggestions?
    Jim Fields
    CAD Design
    Site Development Coordinator
    Trace Creek Construction, Inc.
    www.tracecreek.net
    "Man's mind stretched to a new idea, never goes back to it's original dimensions." - Oliver Wendell Holmes
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    Default Re: Insert Saved View results in - Access Violation. Unable to open drawing.
    Quote Originally Posted by jfields.61630
    Hi Jim,
    Is there any more information with the error message? Could you post the complete error?
    Tim Creary
    S&D
    DILLIGAF
    2003-11
    Ashland, Kentucky
    64
    Tim,
    I finally cleared the error message by saving the drawing which contained the saved view several times. It eventually cleared and allowed me to insert the saved view via the SSM. It was quite frustrating, must have been the gremlins. I appreciate your willingness to help.
    Jim Fields
    CAD Design
    www.tracecreek.net
    Lost
    1,473
    Tim,
    No problem, Jim.
    Just an idea for the future: Maybe an AUDIT of the drawing would have helped?
    Take care.
    Tim Creary
    S&D
    DILLIGAF
  1. 2014: Access Violation when trying to add a named view to sheet
    By j_washbourne28 in forum AutoCAD Sheet Set Manager
    Last Post: 2014-03-24, 10:30 AM
  2. AutoCAD 2007 and 2008 unable to open a DWG file saved in 2004 format
    By Neo_Richard_Blake in forum AutoCAD General
    Last Post: 2007-07-09, 08:50 PM
  3. Open AutoCAD with the last saved drawing file
    By Bear31831 in forum AutoCAD General
    Last Post: 2007-04-06, 09:13 PM
  4. Unable to access / open the Plot Style Manager
    By jnagel in forum AutoCAD General
    Last Post: 2006-11-16, 05:29 AM
  5. Replies: 8
    Last Post: 2006-05-01, 06:39 PM
