Thread: **AcDbZombieObject objects cannot be referenced**
    I could stop if I wanted to rhayes.99001's Avatar
    2005-11
    New Jersey
    349
    Default **AcDbZombieObject objects cannot be referenced**
    When Tring to do an xref edit I get this error.????
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    Default Re: **AcDbZombieObject objects cannot be referenced**
    Quote Originally Posted by rhayes.99001
    From what I've read, delete all of the layer filters in the drawing and source drawings and audit the drawing first. If not sucessful, try the method HERE, which involves repathing the xrefs.
    HTH
    Time Lord Steve_Bennett's Avatar
    2015-12
    far, far, far away...
    4,730
    Zombie objects! What next? Mummy objects?
    Steve Bennett |BIM Manager
    Taylor Design | Adventures in BIM
    2002-07
    5
    Don't know if you had a resolution to your original problem. I've had this same message pop-up when trying to REFEDIT blocks - not xrefs. The work around that I've had success with is to redefine the block within the drawing where the problem occurs.
    2019-01
    ZOMBIEKILLER works great!!!!!
  1. Maintain references off all referenced objects and items while splitting objects
    By Wish List System in forum Revit Structure - Wish List
    Last Post: 2014-01-12, 04:44 PM
  2. Surface says it is already referenced
    By smatt in forum AutoCAD Civil 3D - Surfaces
    Last Post: 2010-03-25, 10:12 PM
  3. Finding a referenced PSD?
    By thillhouse in forum ACA General
    Last Post: 2008-01-10, 04:32 PM
  4. AcDbZombieObject
    By roberto.vasquez in forum ACA General
    Last Post: 2006-05-30, 11:45 AM
