Results 1 to 9 of 9
Thread: Basics Question - "hovering and highlighting"
    100 Club boofredlay's Avatar
    2006-03
    Huntsville, Alabama
    195
    Default Basics Question - "hovering and highlighting"
    When you hover over an object it highlights, obvious. Is there a way to turn that feature off?
    Maybe it is because I am on DayQuill for a cold but everytime the titleblock starts to "flash" when I move over the screen I start feeling motion sick
    Thanks for any information.
    Eric
    100 Club mschroeder's Avatar
    2005-06
    Boston
    154
    Default Re: Basics Question - "hovering and highlighting"
    Not possible. (well.. if you check "Editable only" in the options bar on a workset enabled project then only elements you own will pre highlight.)
    The pre highlighting behavior is integral to the selection process. Often you will need to "tab" over an object to chain up a selection, or to pass over a selection. I find it useful more than annoying.
    regards
    100 Club CADNate's Avatar
    2015-12
    Lovejoy, GA.
    125
    Quote Originally Posted by boofredlay
    Your highlighting stuff can be changed in Tools/Options/Selection under visual effects.
    Hope this helps and I pray that you feel better.
    -Nathan
    2006-03
    Huntsville, Alabama
    195
    Quote Originally Posted by jntopper
    You are talking Autocad dude... I am talking Revit. Sorry for not clarifying that sooner and yes, I am feeling better; thanks.
    Eric
    2003-04
    236
    Stop hovering so long, keep moving, never had this problem unless you just aren't moving your mouse/
    2006-03
    Huntsville, Alabama
    195
    Quote Originally Posted by Steve Jager
    I have no idea what you mean.
    When you move your mouse over an object, it highlights and when you move away, it "un-highlights". I was simply asking if there was a way to turn that option off, like in Autocad.
    Again, sorry if I was confusing.
    Eric
    2002-02
    St. Louis, MO
    4,695
    No. There is no such option.
    Don't drink the Kool-Aid...
    Aaron Rumple, AIA
    I could stop if I wanted to whittendesigns's Avatar
    2004-07
    330
    I'm not sure, but if there was an option to do this, how would you know what you're picking? If you needed to tab through something, I can't see how you would be able to know what exactly it is you are selecting. Just a thought.
    2006-03
    Huntsville, Alabama
    195
    I understand that but the option is there in Autocad.
    Maybe a Function key to toggle on/off the highlight feature. Most things I am picking I don't need to toggle through with the tab key. But if I needed to... "F11" or something. Just a thought.
    Eric
  1. 2014: "Preserve Result Highlighting"
    By RevitNinja in forum NavisWorks - General
    Last Post: 2013-11-18, 04:22 PM
  2. Replies: 8
    Last Post: 2012-08-18, 01:31 AM
  3. Unable to highlight Object sby "hovering over" with mouse.
    By pirit4 in forum Revit Architecture - General
    Last Post: 2011-10-17, 06:20 PM
  4. RAC 2009 keeps "highlighting" roof above plan
    By iru69 in forum Revit Architecture - General
    Last Post: 2008-06-23, 11:01 AM
  5. Code for "Basics of the Revit API" at AU2007
    By Danny Polkinhorn in forum Revit - API
    Last Post: 2007-02-08, 07:41 PM
