Hi everyone,
I want to insert a .BMP file - an image of a row of numbers into the assembly file. I could insert it but it's not show up on .idw file. Can somebody help me with this?
Thanks
Hi everyone,
Thanks
yeah - it is normal that the bmp is not shown in the drawing - because the drawing only projects solid edges that can be found in the model.
When you you turn on the shading of the drawingview, the bmp should appear
Thanks, you right. It's showed up into shaded version. So, I don't have choice to show up into .idw if it's not shaded. Thanks again for your answer.
Hi everyone,
I want to copy all the linked file typed in work group paths of one folder to others folders without introduce them by typing. How can I do this only copying them?
