Thread: Scale default setting in Titleblock
    2006-05
    Windsor, Ontario
    34
    Default Scale default setting in Titleblock
    I have set up a custom title block with at scale parameter that updates with each sheet. Our only problem is that when there are multiply scales on a sheet it gives an ugly note of "as indicated
    I was wondering if there is a way to change the "As Indicated" note to something else.
    If anyone has any ideas I would really appreciate it.
    Thanks.
    All AUGI, all the time ford347's Avatar
    2005-01
    Oroville, CA
    874
    Default Re: Scale default setting in Titleblock
    See This Thread regarding the same issue.
    Josh
    2006-05
    Windsor, Ontario
    34
    Thanks for your help
  1. Change text 'as indicated' with 'scale'parameter on titleblock?
    By studiodd in forum Revit Architecture - Families
    Last Post: 2011-10-25, 05:04 PM
  2. Invalid argument scale in setting standard scale property
    By gtepe.123006 in forum AutoCAD General
    Last Post: 2008-12-23, 02:10 AM
  3. UCS Default setting
    By dhagen in forum ACA General
    Last Post: 2008-08-19, 04:20 PM
  4. Scale bug on Titleblock?
    By dbaldacchino in forum Revit Architecture - General
    Last Post: 2006-09-01, 09:25 PM
  5. Metric titleblock does not scale properly
    By stephane.laferriere in forum Dynamic Blocks - Technical
    Last Post: 2006-08-05, 06:42 AM
