Results 1 to 7 of 7
Thread: Vote for Revit to have a V-Ray rendering plugin
    Member jason.74650's Avatar
    San Diego California
    21
    Default Vote for Revit to have a V-Ray rendering plugin
    2005-07
    Somewhere in the BIM world
    3,792
    Default Re: Vote for Revit to have a V-Ray rendering plugin
    Done, that would be great but i would not mind getting the AutoCAD 2008 rendering engine instead of Accurender.
    AUGI Addict blads's Avatar
    2015-10
    out cycling somewhere... I wish...
    2,285
    Revit is not doing that well in the "V-Ray Polls"...
    Cheers @blads
    Mac Geek | Building Design Suite 2020 | Semi-Retired Building Designer / CAD-BIM Trainer | Autodesk Certified Professional
    AUGI Addict luigi's Avatar
    2015-11
    Royal oak, Michigan
    1,513
    It isn't working properly!
    You attached an image, so it should be static, not live with the web page....I voted for Revit, and it says that Revit is tied with Form Z with 142 votes each...it didn't count my vote!
    2003-11
    442
    Quote Originally Posted by luigi
    Sure it is. The image Blads posted shows FormZ with 142 votes and Revit with 128 votes & 1044 total votes. Now it shows FormZ still with 142 votes and Revit with 131 votes & 1047 total votes. You must have been looking at the Cinema4D votes...
    All AUGI, all the time dpasa's Avatar
    2004-08
    Greece
    637
    It is enough to vote for a fully working API, to make easy for the other companies write the plugins.
    That way, we can have Vray plugin, Maxwell plugin etc...
    2015-11
    Royal oak, Michigan
    1,513
    Quote Originally Posted by muttlieb
    I think you are right...but currently Form Z is ahead of them all....with over 600 votes....hmm...I better double check, unless I make the same mistake :P
  1. Revit MEP Wish List Vote is On!
    By David Harrington in forum Revit MEP - Families
    Last Post: 2010-10-06, 08:36 PM
  2. Revit MEP Wish List Vote is On!
    By David Harrington in forum Revit MEP - General
    Last Post: 2010-09-03, 08:09 PM
  3. Revit Structure Wish List Vote is On!
    By David Harrington in forum Revit Structure - Families
    Last Post: 2010-08-27, 11:24 AM
  4. Revit MEP Wish List Vote is On!
    By David Harrington in forum Revit MEP - Tips & Tricks
    Last Post: 2010-08-18, 11:05 AM
  5. Revit Structure Wish List Vote is On!
    By David Harrington in forum Revit Structure - Tips & Tricks
    Last Post: 2010-08-18, 11:02 AM
