Hello Opie,
When I used "LABEL POSITION" command, at that time continuously I got an "error-function-cancelled". Please help me sir!!
My code is below,
(defun c:lbl ()
(setq objs (ssget))
(setq ref_point (getpoint "pick a point"))
(setq ref_pointx (car ref_point))
(setq ss_len (sslength objs))
(setq count 0)
(repeat ss_len
(setq obj (ssname objs count))
(setq objp (entget obj))
(setq objc (assoc 10 objp))
(setq objx (car (cdr objc)))
(setq objy (car (cdr (cdr objc))))
(setq objj (assoc 72 objp))
(setq objh (assoc 40 objp))
(progn
(setq objj_new (cons 72 0))
(setq objp (subst objj_new objj objp))
(entmod objp)
(setq objc_11 (cons 11 (list 0 0 0)))
(setq objc_10 (cons 10 (list ref_pointx objy 0)))
(setq objp (subst objc_10 (assoc 10 objp) objp))
(setq objp (subst objc_11 (assoc 11 objp) objp))
(entmod objp)
(setq count (+ count 1))
(defun c:lbr ()
(setq objs (ssget))
(setq count 0)
(repeat ss_len
(progn
(setq objj_new (cons 72 2))
(entmod objp)
(setq objc_new (assoc 10 objp))
(setq objx_new (car (cdr objc_new)))
(setq objx_delta (abs objx_new))
(setq objc_x1 (- ref_pointx objx_delta))
(setq objc_x2 ref_pointx)
(setq objc_y1 objy)
(setq objc_y2 objy)
(setq objc_10 (cons 10 (list objc_x1 objc_y1 0)))
(setq objc_11 (cons 11 (list objc_x2 objc_y2 0)))
(setq objp (subst objc_10 objc_new objp))
(entmod objp)
(defun c:1()
(command "ucs" "world")
(setq objs (ssget))
(Setq scalef (/ (cdr(assoc 40(entget(ssname objs 0))))9))
(setq x_x (* scalef 4.0))
(setq y_y (* scalef 4.0))
(setq text_gap (* scalef 16.0))
(setq text_height (* scalef 9.0))
(setq osm (getvar "osmode"))
(command "osnap" "qui,end")
(setq cxy (getpoint "pick a point"))
(command "osmode" 0)
(setq cx (car cxy))
(setq cy (car (cdr cxy)))
(setq count 0)
(repeat ss_len
(if (= count 0)
(progn
(setq tx1 (+ cx x_x))
(setq ty1
(+ cy
(/ (+ (* (- ss_len 1.0) text_gap) text_height)
2
(setq tx2 tx1)
(setq ty2 (- ty1 text_height))
(setq ty2 (- ty2 text_gap))
(setq objc_10 (cons 10 (list tx2 ty2 0)))
(setq objp (subst objj_new (assoc 72 objp) objp))
(entmod objp)
;(setvar "osmode" osm)
(setq lpx1 (+ cx (* 12.0 SCALEF)))
(setq lpx2 cx)
(setq lpx3 cx)
(setq lpx4 lpx1)
(setq lpy1 (+ ty1 x_x))
(setq lpy2 lpy1)
(setq lpy3
(- ty1
(+ (+ (* text_gap (- count 1)) text_height) (* scalef 5.0))
(setq lpy4 lpy3)
(setq lp1 (list lpx1 lpy1))
(setq lp2 (list lpx2 lpy2))
(setq lp3 (list lpx3 lpy3))
(setq lp4 (list lpx4 lpy4))
(setq clay (getvar "clayer"))
(setvar "clayer" "0-25text")
(if(> ss_len 1)
(progn
(command "pline" lp1 lp2 lp3 lp4 "")
(setvar "clayer" clay)
(defun c:2()
(command "ucs" "World")
;(c:xpl)
(setq objs (ssget))
(setq
scalef(/ (cdr(assoc 40(entget(ssname objs 0))))9))
(setq cx (car cxy))
(setq count 0)
(repeat ss_len
(if (= count 0)
(progn
(setq tx1 (- cx x_x))
(setq ty1
(+ cy
2
(setq tx2 tx1)
(entmod objp)
(setq objj (assoc 10 objp))
(setq objjj (assoc 11 objp))
(setq objjx (car (cdr objj)))
(setq objjjx (car (cdr objjj)))
(setq deltaxx (- objjjx objjx))
(setq objc_11 (cons 11 (list tx2 ty2 0)))
(setq objc_10 (cons 10 (list (- tx2 deltaxx) ty2 0)))
(entmod objp)
(setq lpx1 (- cx (* SCALEF 12.0)))
(setq lpx2 cx)
(setq lpx3 cx)
(setq lpx4 lpx1)
(setq lpy2 lpy1)
(setq lpy3
(- ty1
(setq lpy4 lpy3)
(if(> ss_len 1)
(progn
(DEFUN C:33 (/ d pt1 pt2 pt3); start of ext
(load "error")
(initerr)
(adderr
(list 'setvar "osmode" (getvar "osmode"))
(adderr
(list 'setvar "orthomode" (getvar "orthomode"))
(adderr
(list 'command "layer" "s" (getvar "clayer") "")
(setvar "cmdecho" 0)
(setq sc (getvar "DIMSCALE"));REV 9-21-98
(setvar "orthomode" 0)
(setq d (* 0.046875 sc))
(command "osnap" "int,center")
(command "layer" "s" "0-25text" "")
(setq pt1 (getpoint "\nFirst point: "))
(command "osnap" "none")
(setq pt2 (getpoint pt1 "\nSecond point: "))
(setq exangle(angle pt1 pt2))
(setq newpt1(polar pt1 exangle d))
(command ".line" newpt1 pt2 "")
(command "circle" pt1 d)
(setvar "orthomode" 1)
(setq pt3 (getpoint pt2 "\nExtension line location and length: "))
(command ".line" pt2 pt3 "")
(reset nil)
) ; end of ext
