Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Flip Dynamic Block with Attributes does not update insertion points of Attributes
    2007-02
    6
    Default Flip Dynamic Block with Attributes does not update insertion points of Attributes
    See image with this post:
    O.k. I got a dynamic level bubble with text attributes under the bubble. When I flip the bubble with a vertical flip action the text attribute insertion point does'nt change locations. So when I edit the attribute the text is not under the level bubble but beside it cause of the insertion point. Is their a solution to this.
    Thanks boys ans girls
    AUGI Addict .chad's Avatar
    2006-04
    is it lunch time yet?
    1,129
    Default Re: Flip Dynamic Block with Attributes does not update insertion points of Attributes
    check the DB forum. i believe there are a few posts similar to this. otherwise, from what i remember - attributes dont play well with flips, particularly when you want them to line up in a certain way. the only thing i can think of off hand is to set your attributes to a center justification. are you able to post the block?
    2005-06
    in the upper right corner
    3,507
    Yup, Chad_C is correct. I had the same issue.
    Rico pointed out that you cant "flip" attributes and have them "flip" justifiation.
    Your best bet is a different visability state for this.
    2007-02
    6
    Thanks man, Thats what I had in mind. To have different visibility states or different insertion point.
    Thanks guys, I will check the DB forum.
    13,656
    Hi "pasles"
    Please note I have *moved* this thread from the AutoCAD 2007 General forum to this one...
    Thanks, Mike
    Forum Manager
    All AUGI, all the time Mlabell's Avatar
    2004-12
    Toledo, OH
    513
    Quote Originally Posted by pasles
    You may want to keep in mind with the attributes to label the Tags as "Flipped-..." so that if or when you extract the data you know the difference in data.
    2005-06
    3,507
    Quote Originally Posted by marklabell
    Oh Yea,
    With two visibility states with two different sets of attributes, you shoud name your attribute tags differently, like add an "L" and "R" to them so you can tell them apart.
    Retired Forum Staff Rico's Avatar
    2005-06
    In the hospital cuz of my fever for more cowbell
    1,828
    Quote Originally Posted by tedg
    Oh Yea,
    Not only that. Remember that attributes also don;t play nice with each other unless they are entirely unique within that block.
    [SIGPIC][/SIGPIC]
    Return of the Cowbell
    2001-01
    81
    Has anyone tried to use the "block attribute manager"? Use this to "Sync" your dynamic block after the flip . . . . I believe this will update the justification of the attributed text.
    2004-12
    Toledo, OH
    513
    Quote Originally Posted by tknapp
    The justification doesn't sync up like you would expect it to. If you hit sync, then exit the "battman" the justification will be unchanged, which is a programming oversight by autodesk. Maybe in 2009 it will change, but it remains unchanged in 2008 (as far as I know).
  1. Create a dynamic block with multiple insertion points
    By danielk in forum Dynamic Blocks - Technical
    Last Post: 2012-09-07, 08:38 AM
  2. Dynamic Block / Attributes Auto Update
    By jesse732900 in forum AutoCAD General
    Last Post: 2012-04-03, 09:55 PM
  3. Replies: 18
    Last Post: 2010-02-11, 09:54 PM
  4. Why I can not update the block's attributes
    By nfyu in forum VBA/COM Interop
    Last Post: 2009-02-25, 01:18 PM
  5. Is it possible for a Dynamic Block to have multiple Insertion Points
    By TerribleTim in forum Dynamic Blocks - Technical
    Last Post: 2007-06-16, 10:36 PM
