It's not a vanilla AutoCAD command. It is usually found in the verticals.Originally Posted by dzatto
Also, check out archived course "ATP136 Have You Met QSelect?"
Hi "seanp"Originally Posted by seanp
Please note I have *moved* this thread from the AutoCAD 2007 General forum to this one...
Thanks, Mike
Forum Manager
HiOriginally Posted by seanp
Via the AUGI forums...
Block Counting Tool
Via the Autodesk Discussion groups...
Block Count
counting blocks in a drawing
Blocks Listing & Counting
Using FILTER command for block count...
Have a good one, Mike
No. It's not even in AutoCAD - it's an ADT(?) thing.Originally Posted by dzatto
Not sure if this command works in LT or not but you can try the Attribute Extraction Wizard (EATTEXT). It works in vanilla AutoCAD.
It can count blocks and attributes and also build a table for you. It does not require the blocks contain attributes.
Unfortunately with LT you don't have the best tools to acccomplish this. You can't use LISP routines, and you don't have the Enhanced Attribute Editor. Your best bet is to use Quick Select. In the Object Type specify: Block Reference, and then on properties select the "Name" option , on operator select equals, then on value select the name of the block you want Hit OK and it should select all the blocks and report how many it found on the command line.
Ty
ADT/ABS yes, SelectSimilar was available in MAP2006 as well, but, not 2007Originally Posted by jaberwok
One of my friends from the Adesk Discussion Groups wrote a routine that functions in the same way, but, unfortunately, it is lisp, so would not work with AutoCAD LT (darned shame, because I could not work without it now that I have used it).
Melanie Stone
@MistresDorkness
Technical Editornot all those who wander are lost
