Results 1 to 8 of 8
Thread: Draw a Line given 1 point and an angle
    2007-02
    148
    Question Draw a Line given 1 point and an angle
    hi all, like to ask is anyone has any method of ploting a straight with just 1 given point and an angle. don't need to be a code, if you have some interesting algo to get a rough 2nd point to use command "line", i also would like to know. thanks in advance
    2005-07
    2,356
    Default Re: Draw a Line given 1 point and an angle
    Quote Originally Posted by tany0070
    Depending what version of Acad you are using you can do this using the polar tracking, you would just need to edit the angle settings to what you require.
    AUGI Addict .T.'s Avatar
    Lost
    1,473
    Have a look at the POLAR function.
    2015-08
    263
    Hi,
    Just go through this reply for your post, you can see an example.
    Regards,
    Abdul Huck
    2007-02
    148
    thank you all for the help
    2004-02
    5
    At autocad command prompt enter @distance<angle
    Command: line
    LINE Specify first point:
    Specify next point or [Undo]: @10<135
    draws a line 10 units long at 135degs
    2007-02
    148
    that's new (at least for me). thanks
    2007-02
    148
    oh just a thought, if the angle is on the ending plane(i.e. the side i want to reach) is it possible to draw the line?? it's like i want to draw a line from a point to a line, the position of the line is unknown but i know this line will touch this point at an angle. thanks
  1. Draw a line at a specific angle
    By matt__w in forum Revit MEP - General
    Last Post: 2010-08-20, 11:28 PM
  2. draw a line in the point line style
    By rwbaker54 in forum VBA/COM Interop
    Last Post: 2008-04-25, 07:10 PM
  3. Replies: 10
    Last Post: 2007-03-23, 01:50 AM
  4. Draw line from known point to unknown point
    By noadea in forum AutoLISP
    Last Post: 2007-02-09, 02:38 AM
