Hi esaffle,
I'm not understand what are you doing,I only test your code,and test again
(defun c:2dti (/ b_detail b_sheet e i_pt len old_blipmode
pt_2 sc sc_al sc_length s_name s_num t1
t1_pt t2 t2_pt t3 tit_le tit_lenght tit_length)
(setvar "cmdecho" 0)
(setvar "menuctl" 0)
(setq old_blipmode (getvar "blipmode"))
(setvar "blipmode" 0)
(setq sc (getvar "dimscale")) ; get the drawing scale
(if
(or (= s_name nil) (= s_num nil))
(setq s_name "none")
);if
(if
(null (tblsearch "style" "au101s03"))
(command "_style" "au101s03" "arial narrow" (* sc 0.21875) "" "" "" "")
);if
(command "_textstyle" "au101s03")
;(command)
(setq t1 (* (* 0.5 0.125) sc))
(setq t2 (* (* 1.75 0.09375) sc))
(setq t3 (* (* 1.75 0.09375) sc))
(setq s_name "au101s03")
(setq i_pt (getpoint "\nselect start point: ")) ; the pline start point
(setq t1_pt (list (+ (car i_pt) (* 0.0625 sc)) (+ (cadr i_pt) t1)))
(setq t2_pt (list (+ (car i_pt) (* 0.0625 sc)) (- (cadr i_pt) t2)))
(setq tit_le (getstring t "\nenter the title: "))
(setq b_detail (getstring t "\ndetail: "))
(setq b_sheet (getstring t "\nsheet number: "))
(setq tit_lenght (strlen tit_le))
(cond
((= sc 1.0)(setq sc_al "scale: full size"));option 1
((= sc 2.0)(setq sc_al "scale: half size"));option 2
((= sc 4.0)(setq sc_al (strcat "scale: 3" (chr 34) "=1'-0" (chr 34))));option 3
((= sc 8.0)(setq sc_al (strcat "scale: 1 1/2" (chr 34) "=1'-0" (chr 34))));option 4
((= sc 12.0)(setq sc_al (strcat "scale: 1" (chr 34) "=1'-0" (chr 34))));option 5
((= sc 16.0)(setq sc_al (strcat "scale: 3/4" (chr 34) "=1'-0" (chr 34))));option 6
((= sc 24.0)(setq sc_al (strcat "scale: 1/2" (chr 34) "=1'-0" (chr 34))));option 7
((= sc 32.0)(setq sc_al (strcat "scale: 3/8" (chr 34) "=1'-0" (chr 34))));option 8
((= sc 48.0)(setq sc_al (strcat "scale: 1/4" (chr 34) "=1'-0" (chr 34))));option 9
((= sc 64.0)(setq sc_al (strcat "scale: 3/16" (chr 34) "=1'-0" (chr 34))));option 10
((= sc 96.0)(setq sc_al (strcat "scale: 1/8" (chr 34) "=1'-0" (chr 34))));option 11
((= sc 128.0)(setq sc_al (strcat "scale: 3/32" (chr 34) "=1'-0" (chr 34))));option 12
((= sc 192.0)(setq sc_al (strcat "scale: 1/16" (chr 34) "=1'-0" (chr 34))));option 13
((= sc 384.0)(setq sc_al (strcat "scale: 1/32" (chr 34) "=1'-0" (chr 34))));option 14
);cond
(setq sc_length (strlen sc_al))
(if
(> sc_length tit_length) ;((> tit_length sc_length)
(progn
(setq lay1 "text3")
(if
(not (tblsearch "layer" lay1))
(command "_layer" "m" lay1 "c" 1 "" "")
;(command "_layer" "s" "text3" "") it's not need
(command "_text" t1_pt 0 tit_le)
(setq e (entlast))
(setq e (textbox (entget e)))
(setq len (car (cadr e)))
) ; progn
) ; if
(if
(null (tblsearch "style" "bottom"))
(command "_style" "bottom" "simplex" (* sc 0.09375) "" "" "" "" "")
);if
(command "_textstyle" "bottom")
(setq lay2 "text2")
(if
(not (tblsearch "layer" lay2))
(command "_layer" "m" lay2 "c" 2 "" "")
;(command "_layer" "s" "text2" "") it's not need
(command "_text" t2_pt 0 sc_al)
(setq pt_2 (polar i_pt (* pi 2.0) (+ (* (* sc 0.0625) 2.0) len)))
(command "_pline" i_pt pt_2 "")
(command "_pedit" "l" "w" (* 0.03125 sc) "")
(setvar "attdia" 0)
(command "_insert" "2_det" i_pt (getvar "dimscale") "" "" b_detail b_sheet)
(setvar "blipmode" old_blipmode)
(princ)
);defun
