Thread: AU 2005 VBA with Excel Sample Code
    100 Club wpeacock's Avatar
    2015-09
    Bunbury, West Australia
    161
    Cool AU 2005 VBA with Excel Sample Code
    In the process of working through this AU handout, on Integration of AutoCAD VBA with MS Excel by Dave Espinosa, I've come across an error message in this code when I've tried to run it.
    Error Massage: Object doesn't support this property or method. at'
    If ent.EntityType = acBlockReference And ent.Name = bnam Then btot = btot + 1
    1 - Any ideas on why it is doing this?
    2 - What is needed to fix it?
    Thanks
    Wayne
    Note: form requires three comand buttons and the list boxes.
    Public excelApp As Object
    Public wkbObj As Object
    Public shtObj As Object
    Sub CommandButton1_Click()
    Dim i, j, btot As Integer
    Dim bnam As String
    Dim ent As Object
    btot = ThisDrawing.Blocks.Count
    For i = 0 To btot - 1
    bnam = ThisDrawing.Blocks.Item(i).Name
    If Not Mid$(bnam, 1, 1) = "*" Then ListBox1.AddItem bnam
    Next i
    For i = 0 To ListBox1.ListCount - 1
    bnam = ListBox1.List(i): btot = 0
    For j = 0 To ThisDrawing.ModelSpace.Count - 1
    Set ent = ThisDrawing.ModelSpace.Item(j)
    Next j
    ListBox2.AddItem btot
    Next i
    End Sub
    Sub CommandButton2_Click()
    On Error Resume Next
    Set excelApp = GetObject(, "Excel.Application")
    If Err <> 0 Then
    Err.Clear
    Set excelApp = CreateObject("Excel.Application")
    If Err <> 0 Then
    MsgBox "Could not start Excel!", vbExclamation
    End
    End If
    End If
    excelApp.Visible = True
    Set wbkObj = excelApp.Workbooks.Add
    Set shtObj = wbkObj.Worksheets(1)
    shtObj.Name = "Block Count"
    Dim bnam As String
    j = 1
    btot = ListBox2.List(i)
    shtObj.Cells(j, 1).Value = bnam
    shtObj.Cells(j, 2).Value = btot
    j = j + 1
    Next i
    End Sub
    Sub CommandButton3_Click()
    End ‘or ExcelApp.Quit Unload Me
    End Su
    2015-09
    161
    Default Re: AU 2005 VBA with Excel Sample Code
    Frustrated, I exploded the title block and it now works?
    Very confusing....
    All AUGI, all the time zoomharis's Avatar
    2005-02
    Abu Dhabi (Native-India)
    506
    Quote Originally Posted by wpeacock
    Not all Acad entities have 'Name' property. So testing for the entity name with those entities will generate an error. Try the following code to avoid this.
    If ent.EntityType = acBlockReference Then
    	If ent.Name = bnam Then btot = btot + 1
    End If
    This code will first check whether the object type is AcadBlockReference ( which supports the Name property), then check for its name.
  1. Error in a sample code ?
    By Dubweisertm in forum Dot Net API
    Last Post: 2011-09-08, 08:17 PM
  2. Sample code Error
    By r.vetrano in forum Revit - API
    Last Post: 2007-07-09, 11:42 AM
  3. Replies: 0
    Last Post: 2006-04-10, 05:38 PM
  4. Replies: 13
    Last Post: 2004-07-29, 11:38 PM
