Thread: ADT2007 - Wall Hatch
    2007-01
    5
    Default Wall Hatch
    I am using ADT 2007. I have turned on the hatch patterns for CMU and brick. I want the hatch patterns to come in on specific layers when the wall is created. I know that you can change the layer in the display properties of the wall style, I just want to know if there is anywhere else that the settings can be adjusted. We draw multi-level buildings and I just wanted to know if there is a quicker way to adjust the layer of the hatch. Some help would be greatly appreciated.
    Tony Rhine
    JRA Architecture
    2005-09
    Reading, PA
    213
    Default Re: ADT2007 - Wall Hatch
    Have you tried creating a layer set or using a layer filter? You'll probably have to reassign the hatch for the CMU to another layer either way, depending on what other hatches you need that show up on that layer.
    2011-05
    926
    The fastest way to handle hatches is through the "material" display. Set your material to the pattern desired and place it on a specific layer, such as "A-Wall-Patt". Then you will need to go to every wall style affected by the material and change the display setting to "by material". If you ever need to modify that material, then you only do it once, and all the wall styles will pick it up.
    2007-01
    5
    Would it be easier to just use a display theme?
    Tony Rhine
    JRA Architecture
  1. ADT2007 wall clean-up tutorials
    By cadclips81126 in forum ACA/AMEP Tutorials
    Last Post: 2007-04-08, 05:03 AM
  2. ADT2007 - wall display question
    By .chad in forum Style Management
    Last Post: 2007-02-23, 01:48 PM
  3. ADT2007 Slab Interference
    By steve459238 in forum ACA General
    Last Post: 2007-01-22, 10:30 AM
  4. How to make brick wall w stone belt course? ADT2007
    By johni in forum Style Management
    Last Post: 2006-09-29, 09:52 PM
  5. Updated ADT2007 API examples available
    By richard.binning in forum Dot Net API
    Last Post: 2006-04-11, 04:02 PM
