Results 1 to 10 of 11
Thread: Embedded Excel file interfering with our Standard font file (Architxt.shx)
    2004-05
    Chambersburg, PA
    53
    Default Embedded Excel file interfering with our Standard font file (Architxt.shx)
    We have a finish schedule drawing with an embedded excel file. When we open up that particular file, any other files that we open from that point forward have the standard font kicked into another type.
    We run ACAD2007 with Architext as our standard font.
    Thanks for any input!
    13,656
    Question Re: Embedded Excel file interfering with our Standard font file (Architxt.shx)
    Hi
    Is the embedded Excel file an OLE Object or an AutoCAD Object ie a Table?
    Have a good one, Mike
    2004-05
    Chambersburg, PA
    53
    Default Re: Embedded Excel file interfering with our Standard font file (Architxt.shx)
    It is a OLE object.
    2004-05
    Chambersburg, PA
    53
    Here's something else interesting. As mentioned before, when I open up any subsequent drawings after opening the drawing containing the excel files, the fonts are different. Additionally, if I modify anything in any drawing that was opened before, the same effect eventually occurs. The attached sample shows a tag that displays normally. But when I move that tag, the attribute info changes font types. Also, if I perform a print preview on the same drawing that is displaying normally, the preview shows the modified fonts
    interesting......
    13,656
    Hi
    Within AutoCAD are you using TrueType or SHX fonts?
    If TrueType(s), what TrueType(s), and what TrueType(s) are you using in Excel?
    2004-05
    Chambersburg, PA
    53
    hey Mike
    We use a SHX font file (architxt) in AutoCAD and a truetype (Arial) in the Excel file.
    Mike
    13,656
    Quote Originally Posted by mhudson
    Hi
    Am I correct in my thinking that Architxt.shx is not a standard AutoCAD SHX font file ie It does not ship with AutoCAD?
    If yes, maybe try experimenting by replacing Architxt.shx with a standard AutoCAD SHX font... and see what happens.
    2004-05
    Chambersburg, PA
    53
    Well, you're right. I subbed our architxt.shx font with a standard AutoCAD SHX font and the problem did not re-occur.
    What does this mean?
    Thanks
    Mike
    13,656
    Hi
    Honest answer, I do not know... pass...
    Guess... there maybe some technical reason (or possibly a bug) relating to how AutoCAD handles OLE Objects and Text "based" Objects (especially when it comes to non standard AutoCAD SHX font files).
    2004-07
    Baton Rouge, Louisiana
    249
    we use a program called XL2CAD that imports excel files into autocad and it automatically update the file each time you open up the file. all files are inserted at 1=1 scale. we also use a nonstandard font called archquik.shx for our drawings and Arial for XL2CAD. the web site to order it from is www.dotsoft.com, and its very inexpensive to buy.
  1. Embedded Excel File
    By trlear in forum AutoCAD General
    Last Post: 2009-07-15, 06:27 PM
  2. Replies: 6
    Last Post: 2007-04-13, 09:38 PM
  3. Plot to File- Standard file navigation dialog box
    By mcharper in forum AutoCAD Plotting
    Last Post: 2006-05-10, 01:07 AM
  4. Swap old custom font file for new font file
    By dgalloway in forum AutoCAD Customization
    Last Post: 2006-02-02, 03:09 PM
  5. Switch to Architxt font?
    By Scott Hopkins in forum Revit Architecture - General
    Last Post: 2004-04-02, 06:37 AM
