Thread: Problem plotting coincident lines
    2004-07
    Default Problem plotting coincident lines
    Using Autocad 2000, I find that if I have copied a line onto itself, or it is coincident with another object line, both lines will be ommitted in the plot. The same is true for 3D plots which are plotted perpendicular to face or plane. Oblique views of a 3D object shows all lines on the plot.
    Your help will be appreciated.
    m. hufford
    2015-12
    Arizona
    2,478
    Default Re: Problem plotting coincident lines
    Do you have Shade PLOT on?
    Did you happen to HIDE the view prior
    to plotting?
    Also investigate the graphics option for that
    printer and se if it is set to MERGE
    13,656
    Hi
    Have you both the following updates for AutoCAD 2000 installed -
    (English) AutoCAD 2000 Plotting Update Patch
    AutoCAD 2000 Service Pack 2 (Unlocked)
    Please note with the above I've assumed rightly or wrongly you are running the English version of AutoCAD + the American version in relation to Service Pack 2, if I've got it wrong check out the following AutoCAD Download area for the correct updates -
    AutoCADĀ® 2000 Updates & Service Packs
    Have a good one, Mike
  1. Bad lines - Plotting
    By chris622161 in forum AutoCAD Plotting
    Last Post: 2014-04-07, 12:18 PM
  2. Non-plotting lines.
    By Calvn_Swing in forum Revit - Plotting/Printing/Exporting
    Last Post: 2012-12-12, 04:02 PM
  3. 2012: Make a line coincident (and follow) a Pline
    By Sarah.C.Fisher.D1 in forum Dynamic Blocks - Technical
    Last Post: 2012-06-14, 12:45 PM
  4. Lines all over when I am plotting
    By rmoralejo772801 in forum AutoCAD General
    Last Post: 2011-09-30, 07:42 PM
  5. Color lines are plotting lighter than black lines..
    By akall in forum AutoCAD Plotting
    Last Post: 2005-02-04, 09:28 PM
