In recent days I've noticed a couple of issues with the file export to CAD function in Revit. One is the annoying glitch where the units in the exported cad file are set to inches-decimal, and then you open Format/Drawing Setup, and click "Apply", and magically, the units are in feet and inches, in Architectural format.
Another I have discovered came up when exporting wall section sheets. We exported directly from the set up sheets in the central file, and all seemed well at first. You opened the sheet file in autocad, and there was, in paper space, the same sheet laid out just as it was in Revit. Click over to paperspace, and there are the sections xref'd in. The problem arrises when I went to bind/insert the xrefs, since there are about 20 xrefs for each sheet file coming out of Revit. Some annotation elements, like column grid bubbles and section tags, would end up all over the page, completely removed from their context. I had to go through and painstakingly clean up all the little random bubbles scattered about the drawings, and it was a pain.
Any thoughts on what is causing this?
