Results 1 to 10 of 11
Thread: Get current drawing scale, then insert block via that scale
    2006-04
    85
    Question Get current drawing scale, then insert block via that scale
    I've got palettes with blocks on and have to either add a scale action to each block (and manually change each block) or create different palettes for different scales. Is it possible to set up dynamic blocks to automatically look up the current scale setting in the drawing and input that into scale actions within the block?
    I've used a lot of VBA in Access and Excel but none at all in Autocad and I really wish there was a Macro Recorder to help me pick up the key words & functions etc!
    2000-01
    Seattle WA USA
    5,859
    Default Re: Get current drawing scale, then insert block via that scale
    If I'm reading you correctly, you have set up a parameter/action simply to match the block scale to the drawing scale? If so, that is a waste. That's what a block's normal scale factors have been used for over the last two decades.
    2006-04
    85
    Ok, let's try that again.
    I create a simple stretchable arrow as a block which I then put on a palette so that I can drag 'n' drop into drawings. The drawings are at various scales eg. 1:50, 1:25, 1:10 etc.
    If I add a scale parameter to the block, would it be possible to get the block to set itself to the current drawing dimstyle scale? On this simple example it is the size of the arrowheads which have to be scaled as the length has a stretch action anyway.
    2004-07
    Detroit Michigan
    2,508
    I sort of understand what you are thinking.
    In 2007, set each block in the tool palette to use an auxilary
    scale. Use either dimscale or plot scale.
    Hightlight several blocks at one time and the entire palette
    can be changed.
    Is this what you are looking for?
    2006-04
    85
    Not quite. We don't use 'DimScale' but work exclusively in model space and use paper space (with relevantly scaled viewports) for printing purposes. What we would love is for the blocks to pick up the currently selected 'DimStyle'
    The file I've uploaded is a standard I'm creating for reinforced steelwork. Various blocks have been created 3 times to be put on 3 separate palettes depending on dimstyle scale. What would be nice is 1 set of blocks on 1 palette that size themselves automatically according to the currently selected dimstyle scale.
    2000-01
    Seattle WA USA
    5,859
    Exclamation Re: Get current drawing scale, then insert block via that scale
    Quote Originally Posted by david.pugh
    Looking at your drawing shows that, given your description of working only in ModelSpace, your DimStyles are setup incorrectly.
    You have dimension styles for each scale factor, yet in those styles you are not setting the DimScale correctly. The 1 to 50 style should have a dimScale of 50, not 1. All the object sizes, such as arrow heads and text sizes, are manually scaled up to the multiplied value. This is counter to the intended use of DimScale.
    And that is where your other difficulties are coming in.
    See the attached drawing with correct dimension styles. By using those dimension styles you will then be able to use tool palette features as Autodesk intended.
    All AUGI, all the time zoomharis's Avatar
    2005-02
    Abu Dhabi (Native-India)
    506
    Additionally, you may find this thread helpful.
    har!s
    CADing && Coding
    AuotCAD 2010 on Windows XP Professional (SP3)
    2005-02
    95
    Hi!
    I have a same problem that with you. I have solved this problem using dimscale variable. If your scale is 1:100 then change the value of DIMSCALE. when ever you want to insert or draw you can use this variable. I used in autolisp (setq geds (getvar "dimscale")).
    2006-04
    85
    Thanks for the replies people, time for a re-think I think!!
    2011-02
    Orlando Florida
    14
    Not sure if this will help but works for me. My blocks has atrbutes, this inserts to whatever scale is set. Just change tageqpm with you block. Put in on a button.
    ^C^Cattreq;0;^C^C-layer;m;N-MHEQUIPTAG;color;yellow;;;ortho;on;-insert;tageqpm;\(getvar "dimscale");;\-attedit;;;;C^Cate
  1. Block and VP scale insert
    By Techdon1 in forum AutoLISP
    Last Post: 2009-07-02, 03:18 PM
  2. pvi2 block insert scale
    By smcgypsea in forum Land Desktop - General
    Last Post: 2008-10-14, 12:47 PM
  3. Replies: 1
    Last Post: 2007-08-17, 12:37 AM
  4. Insert block definition from one drawing into current drawing
    By ktisdale.118609 in forum VBA/COM Interop
    Last Post: 2006-08-08, 10:28 PM
  5. Insert a Block with default scale set to 1
    By okillham in forum AutoLISP
    Last Post: 2005-05-09, 07:42 PM
